Home > Td5 > TD5 air conditioning wiring |
pic missing PC problems windows 10
1st Jan 2017 3:57pm |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 |
Many thanks that's very good of you. Looking at the diagram it appears I need to wire back to relay R181 and R117. Do you have access to any diagrams that show where these are located if not it seems I will need to make up a loom ?
1st Jan 2017 4:37pm |
two relay are located in drive seat box
1st Jan 2017 4:46pm |
Ah excellent I shall have a good look
1st Jan 2017 4:51pm |
1st Jan 2017 4:57pm |
Catalou66 Member Since: 24 Jun 2019 Location: Paris Posts: 2 |
Hi,
(Sorry for my English because I’m french) I want also to install an Airco coming from a Defender TD5 99 to my Defender TD5 06 but it looks like the pics you posted has disappeared. May you post them again? I really would appreciate it. Thanks a lot in advance! |
24th Jun 2019 10:50pm |
Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 288 |
I can’t see them either... will the diagrams work for 300tdi.. cheers @steve_overland on Insta.
110 expedition vehicle with pop roof |
24th Jun 2019 10:56pm |
link to TDI 300 wiring AC too
https://1drv.ms/b/s!AtZSoWFHDgnGjD447hxdHo-gv_oL Last edited by dorsetsmith on 25th Jun 2019 7:53am. Edited 1 time in total |
25th Jun 2019 7:22am |
Ac fuse are different places between TD5 99 and TD5 06 main loom as the centre fuse box changed post 02 face lift will re post then Last edited by dorsetsmith on 25th Jun 2019 8:22am. Edited 1 time in total |
25th Jun 2019 7:29am |
Click image to enlarge Click image to enlarge MY 1999 to 2000 Last edited by dorsetsmith on 25th Jun 2019 9:43am. Edited 1 time in total |
25th Jun 2019 7:55am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6485 |
Td5 and 300 Tdi in here (2002MY):
https://www.defender2.net/gallery/albums/u...IONING.pdf 1988 90 Td5 NAS soft top 2015 D90 XS SW |
25th Jun 2019 9:04am |
Thanx a lot!
25th Jun 2019 4:08pm |
MYSTERY Member Since: 14 Jun 2019 Location: Torquay Posts: 10 |
ONE SHEET
Click image to enlarge |
28th Jul 2019 9:44pm |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 157 |
technically, you don't need to get the AC unit to talk to the ECU.
Pro: When it's wired to the ECU, the ECU can control when to "request AC clutch" and when to "request AC fan". When the driver turns on the AC, he "request AC" to the ecu via the 12v AC request at high. The ECU then checks the operating conditions like engine temperature and engine rpm. If the temperature is ok and the engine is not labouring, the ecu will then "request AC clutch" and then "request AC fan". If the engine temperature is high, the ECU can also use the "request AC fan" to aid cooling If the engine rpm is high, then it will not immediately "request AC clutch" When "AC clutch request" is made, depending on the RPM, there's a table in the ECU map to inject more fuel and it tapers down around 4000rpm. Con: Let's not complicate the install as you will need to mess around with the ECU pins and such to get those to close the correct relay. If using a manual AC unit, when the AC clutch and fan are on, the ECU will already know how to compensate for the drop in RPM when idling so there's no adjustment to do. Having a separate AC system from the ECU is easier to isolate if something goes wrong. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
29th Jul 2019 1:27pm |
