Home > V8 > Weber Edelbrock 500 vs SU carburettors
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
Does anyone on here have any experience with the Weber Edelbrock 500? Thinking of swapping to them as I heard they're better than SU's in pretty much every way.. Any experience and pictures welcomed Smile 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #576715 10th Nov 2016 3:31am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
I had looked at replacing the boxer setup on my Bowler with a Weber 500 but decided against it as some of the other guys using them were having problems with getting them to run reliably off road Thumbs Up 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 250D XS
Post #576727 10th Nov 2016 7:54am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I had an Edelbrock 500 and it was great except on very steep inclines where it would stall. I bought some spring-loaded off road needles, but never got around to fitting them.
I also found that you could get vapour lock where the petrol in the bowls would boil. I fitted a phenolic spacer to lift the carb off the engine block and insulate it, this seemed to help.
Post #576743 10th Nov 2016 10:36am
charcoal
Interesting, never heard of either of those problems. Is the petrol boiling a problem caused by off roading too or just running for long periods of time? 1999 Land Rover Defender 110 td5 station wagon
Post #576804 10th Nov 2016 2:55pm
Iggle piggle
United Kingdom 1989 Defender 90 V8 Petrol ST Alpine White
I've had no experience of the Weber Edelbrock set up, but can I ask why you are thinking of going down this route?
More power? better MPG? or are you having problems with the SU's?
Post #576813 10th Nov 2016 3:20pm
Inigo
Petrol boiling only happened on a few occasions. Once was very hot day off roading in sand, high revs, low speed, the other was sitting in traffic queue for Eurotunnel on a hot day, it stalled at the ticket booth and I had to get the guy to help me push it out of the way. Whilst waiting for the Eurotunnel tow truck it cooled down enough to restart and I managed to drive off.
Adding the 10mm-ish thick insulating spacer was enough to stop it happening again.
Post #576819 10th Nov 2016 3:43pm
charcoal
More power would be the main reason, heard of people getting 20-30 horses from it. Don't want fuel injection also. It would also be nice to have one carburettor so balancing is no longer required.
Did it run normally after you were able to drive off? Was the engine temperature too high on the fuel gauge? 1999 Land Rover Defender 110 td5 station wagon
Post #577015 11th Nov 2016 12:19am
Inigo
And the sound, the throaty induction roar as the secondaries open up was wonderful.
It drove perfectly after it had cooled down a little and wasn't showing in the red zone on the temp gauge.
Initially I had overheating problems, but added new viscous coupling for fan, had the exhaust manifolds zircotech coated and changed the temp sender and gauge for VDO so I got a better idea of what actual temps were. Petrol boiling in carbs seemed to be a heat soak thing, so normal heat from engine was enough to boil petrol in traffic. The spacer sorted it out and was simple to fit. I was concerned that there would be enough room under the bonnet, but it was fine.
Post #577045 11th Nov 2016 9:57am
charcoal
Doesn't sound like a deal breaking problem then, do you have any pictures of the setup? 1999 Land Rover Defender 110 td5 station wagon
Post #577141 11th Nov 2016 4:24pm
muddypaws
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Only just found this thread.
My old cobra had an Eddie in it.
A great carb to work on & very adjustable but a 500cfm would certainly very much overfuel a standard 3.5 in a low state of tune.
John Eales used to use SU's right upto 250bhp & if they are jetted right, I am sure they are your best bet as they work well on all sorts of inclines Richard
Defender 90 SVX
Post #585006 14th Dec 2016 2:35pm
muddypaws
 Richard
Defender 90 SVX
Post #585010 14th Dec 2016 2:39pm
Romadog
Su's all day long !
Thumbs Up
Post #585077 14th Dec 2016 7:06pm
charcoal
At the price the conversion kits cost it wouldn't be something I could do any time soon anyway. If my problems are stemming from the su carburettors then it'll be easier to just get a new pair. Also that engine bay looks fantastic muddypaws Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
Post #585486 16th Dec 2016 1:14am
Morepower
New Zealand
Burlen Fuel systems are the people to speak too regards spares and new/reconditioned carbs... They have the rights to the SU/Amal and others... Really nice people to deal with and definitely know their product... Hope this helps
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #585503 16th Dec 2016 7:36am
charcoal
Thanks for the suggestion Tim, just contacted them with regards to a replacement pair of hif44s. Don't know how I didn't find them before! 1999 Land Rover Defender 110 td5 station wagon
Post #585698 17th Dec 2016 1:38am
