Home > My Defender > A second 110 on the drive - 300tdi csw BMW powered! |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10530 |
1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
13th Nov 2016 9:03pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1190 |
No problem. Just glad it didn't fall off Steve's 110 on the way between Whitchurch and Chester... Glad we (through luck more than anything) bungeed it on securely. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
13th Nov 2016 9:14pm |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 287 |
Grabbed some time on the 110 the last couple of days, fitted the replacement crossmember along with high grade stainless nuts and bolts (from yrm). Next I moved onto the rotten c pillar on the drivers side, again I used a yrm part which was a spot on fit. I braced the door b and c pillar half way up just to be sure and took a load of measurements before attacking it with the angle grinder. Anyway after a few hours labour I was left with this- apologies for the poor camera picture.
[URL=] Click image to enlarge[/URL] Ran some seam sealer on the edges and it's ready for some undercoat/ and internal cavity protection. Also managed to pick up the correct coloured green spray paint from halfrauds so will use that to finish it off. Also got the freshly painted tank back in place and treated the surrounding chassis with dintrol beforehand. Lastly thought it was best to put some fresh antifreeze in as I tested the existing fluid and it didn't seam that strong. So overall a pretty productive time, where noting went wrong for a change. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
27th Nov 2016 8:21pm |
Good result you got there, moving forward a bit more 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
27th Nov 2016 8:43pm |
Cheers L110CDL
Anyway have now tackled the c post on the opposite side, I did consider just cutting out the bottom half, however thought better of it and fitted the whole section. Just now need to the prime and paint it as per the drivers side. Also order a couple of rear quarter panels as the aluminium had seen better days on the originals. Click image to enlarge Pretty please how the paint came out, I had painted the chequered plate that goes over the panel but will see how good a match the panel is against the rest of the vechicle before I decide if the chequer plate goes back on. Hopefully get both of them fitted this weekend if the sealed rivets I ordered turn up. Also been painting some of the other chequer plate - here's a few more poor camera phone pictures Click image to enlarge Click image to enlarge 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
7th Dec 2016 10:35pm |
That painting is really good on another note, may i ask what is under the blue sheet ? is it the Dax ? 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
7th Dec 2016 11:13pm |
Thanks, still got to lacquer it but it's pretty good seeing how I did it. The blue sheet is protecting this from me knocking it
7th Dec 2016 11:20pm |
Very nice Never seen that type of wheel rim before on a Beetle, thinking about it, on any car 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
7th Dec 2016 11:23pm |
Cheers, as for the the wheels - they are JGE and are copies of a Porsche 914 gas burner wheel. However the centre caps are genuine porsche thanks to eBay. 1999 300TDI 110 CSW BMW 3.0
8th Dec 2016 12:05am |
Thanks for the reply, they are nice and they suit the beetle 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
8th Dec 2016 12:24am |
Cheers.
Managed to grab some time today to fit the rear quarter panel. Instead of using the rusty washers that pack out the rear of the quarter panel so it lines up with the the rest of the panels, I made some ali spacers up before fitting them on the rivets then attaching to the c post. After a bit of adjustment it sat pretty well. Will most probably reattach the chequer plate and the new paint is a shade darker than the rest of the body. Click image to enlarge Also fitted the ali repair panel on the front of the passenger side inside wheel arch. As per the drivers side I also bonded it prior to riveting it. Will be soundproofing these panels along will the rest of the rear floor. Click image to enlarge Before the light went, I added a coat of green to the passenger side c post that I did last weekend Click image to enlarge Welding wise I think that's now the c posts are done, the only other welding type thing is to fabricate the lower brackets that join the roll cage to the chassis, they are either not fitted or are slightly angled wrong so will need some type of adjustment. I had thought about seeingif I could purchase new ones however I can't seem to find any sort of manufacturer details on the cage. 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
10th Dec 2016 6:47pm |
Making good progress there Ib73, as for the roll cage i cant help you there but you put a thread up asking the forum for there input 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
10th Dec 2016 9:56pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4942 |
looking great
11th Dec 2016 2:12am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10363 |
Top job.
11th Dec 2016 8:16am |
