Home > Td5 > Rear mud flaps |
Guessing a 90 or you'd simply compare sides ??? (I drive 110 where it's symmetrical) Solved the bowel problem, working on the consonants...
26th Oct 2016 12:32am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2262 |
His profile says 2003 90 TD5 XS.
The rear mud flaps are attached to the underside of the crossmember with three bolts which go into captive nuts. If the crossmember has corroded (very common at the corners where the mud flaps are) the captive nuts can fall out, causing the mud flaps to come loose and hang by the inner bolts only. |
26th Oct 2016 8:02am |
mustafasoleiman Member Since: 21 Jun 2016 Location: London Posts: 103 |
Thank you for all your help... I am wondering what would happen if I remove all four mud flaps?
Alex |
8th Nov 2016 1:10pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1759 |
Lots of spray. Removing fronts would lead to a horrendous amount of spray up the sides. Rears less of an issue for you, just others that cop it. I really need to put my rears back on....
8th Nov 2016 5:08pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I don't have any mudflap, I loose them off-road anyway. And I doubt mudflaps help to keep my 90 clean.
Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
11th Nov 2016 9:18am |
Rogeo1983 Member Since: 19 Nov 2015 Location: Horsham Posts: 30 |
The rear mudflaps are held in by captive rivnuts. Bit of a pig to replace and you need a rivnut gun. Pretty cheap.
Pm me if you want any further help with it |
24th Nov 2016 2:13am |
