Home > In Car Electronics > I have DAB!
isacs
I have DAB!
Finished installing it all last night in my td5, what a difference! Fender is now a real pleasure to drive again. Fitted a Kenwood BT502DAB mechless, partnered to the Kenwood active sub (mounted to the cubby) with Vibe speakers front and rear
Post #575681 5th Nov 2016 9:05pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
how did you mount the DAB arial?
Post #575692 5th Nov 2016 9:33pm
isacs
On the top right of the windscreen, The ariel came with the unit as well as a microphone for the bluetooth call making. So I removed the A pillar cover, ran the wires behind the instrument cluster and up the side of the screen.
Post #575697 5th Nov 2016 9:54pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Did you enjoy scrapping the paint off the A pillar for the aerial connection ? Crying or Very sad
Post #575698 5th Nov 2016 9:59pm
bm52
i take it the aerial is an internal stick on then?
Post #575699 5th Nov 2016 9:59pm
isacs
Yeah came in the box. i'd done some research on here and the rest of the net about dab aerials and if fitted right they seem ok.
Post #575706 5th Nov 2016 10:16pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
I fitted an external one in the place of the original, was a bit pricey though, £47 if I remember correctly, worht it though Thumbs Up Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #575737 6th Nov 2016 2:04am
isacs
Didn't need to scrape anything, as long as the earth tab was on metal it was fine. The fact that you stick it to a surface surely can't mean it's vital it's bare metal
Post #575755 6th Nov 2016 9:26am
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
Fit an external one ! Miles better than the screen mount
Post #575770 6th Nov 2016 10:38am
isacs
If i have issues at some point with reception then i'll look into an alternative
Post #575798 6th Nov 2016 1:49pm
mse
Just fit a unit and use the factory original aerial for dab Thumbs Up Mike
Post #575885 6th Nov 2016 7:33pm
