Home > Puma (Tdci) > Strange 'clunking' noise when you come off the power |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2284 |
Hi Sticky I have the very same. Just when hot. I d not know what it is. |
25th Dec 2008 2:02am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I had the same thing.
Exactly the symptoms you describe. It is usually cured by bringing the LR to a stop on the handbrake. The dealer suggested it was 'a bit slack' and tightened it. However, it has just come back after a couple of weeks. Did they replace your handbrake or adjust it? Is it likely to be doing damage elsewhere along the transmission? |
28th Dec 2008 4:07pm |
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 |
It is the dealer tomorrow, so I will let you know what they have to say.
29th Dec 2008 12:10am |
All solved, apparently the whole lot was changed but didn't get a chance to speak to the mechanic.
I drove in heavy traffic and motorway sections that would normally show up te symptons and it is definately no longer there. |
30th Dec 2008 12:20am |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
Hi all
I noted my handbreak drum was rubbing somewhat but the break lever has to be up three clicks to work on a steep hill. I also checked that the drum was not overheating so I was wondering - if the drum were oval would I be able to check this with a dial gauge on the outside of the drum or would only the machined inner drum be checked in accordance with the bore/spiggot? I did try to adjust the break myself until the breaks stop rubbing but at this stage the lever is too slack and does not break at all. Thanks James Puma 110 - gone Series III 1973 - going strong |
30th Dec 2008 2:31pm |
austen Member Since: 11 Mar 2008 Location: Sydney Posts: 52 |
My handbrake is up 6 clicks to avoid this annoying problem. Sticky, did you experience a grinding noise when coming off the power and re-applying between 100 - 110kph?
Austen. |
31st Dec 2008 7:50am |
Austen, i'll be honest, once I heard the noise I backed off using the car for fear of related issues.
I do remember getting a slight grinding noise once or twice which has since gone away. I am not convinced that we have heard the end of this problem as like you I now have more travel on the hand brake than I like. I may have a chat to X-eng and see if the brake fits just to see the back of this http://www.x-eng.co.uk/X-BrakeSeries.asp |
31st Dec 2008 9:47pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5029 |
On the x brake - ive never liked them and cant see the point in them on any of our Land Rovers.
Also after the recent court case...i wouldnt want to mess with the braking system. Mike |
1st Jan 2009 5:03pm |
