Home > Maintenance & Modifications > Reverse light |
Defender marto Member Since: 14 Mar 2016 Location: Wirral Posts: 128 |
I had this problem on my td5. Bulb fine, fuse looks fine, so stripped out landy to get at switch on the top of the gear box, put in new switch, no joy . After faffing around trying to fine the fault it turns out is was the fuse, it looked ok but it was not, so cheap option first swap fuse, you never know. But the switch to your is located under the access panel beneath the cubby box and looks like this. Marto
Click image to enlarge |
23rd Oct 2016 8:39am |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
I had the same problem on my Puma 90 My 2010 .
I have fixed the problem with WD40 on the "ball" of the switch and on the connector . Reverse Light Switch`07 on -Part # : LR005160 Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
23rd Oct 2016 8:27pm |
