Home > My Defender > Gordon the 1989 90
alpacaman
Gordon the 1989 90
OK, so it's not 'officially' a Defender but here's my 1989 Land Rover 90 pick up as it arrived home last night. Seems fairly original and unmolested.
Odometer reads 135,000 and it's clearly seen some work judging by the bodywork. However, the chassis seems pretty good (to me at least) – no sign of any rust apart from perhaps the rear chassis legs. Plan will be to give the whole thing a good brush down and oil/Waxoyl/whatever in the Spring.
The TD engine has long gone, and the previous owner put in a ex-MOD 2.5 NA diesel, along with a new Borg and Beck clutch kit and fork. I've no plans to change this unless I have to.
There are a few little jobs to do which should keep me busy over Winter. Drivers door will only open from the inside if you pull the locking button up at the same time as the handle, seats need covers/recovering, radio needs fitting, new bulbs needed in instrument panel, load area needs a lining, cab roof lining needs seeing to, new sliding rear window required, adjustable height tow bar required, wheel rims could do with a repaint, etc. etc. Enough to keep me out of trouble I reckon. Also considering the slick shift mod to cut the gear travel down a bit.
I'm still undecided about the canopy. On the one hand it is pretty solid and won't rip or tear, but on the other I always think they sit too high and make a lot of noise.
Look forward to being able to learn more about these motors from the forum.
Post #568557 4th Oct 2016 10:41am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Nice looking 90 Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #568559 4th Oct 2016 11:02am
dorsetsmith
nice to see good 90 in original shape, nothing wrong N/A 2.5 lot lease to go wrong Thumbs Up
Post #568570 4th Oct 2016 11:59am
shaggydog
Very honest looking truck Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #568576 4th Oct 2016 12:45pm
Tinytim
Nice original farmer spec 90.
I wasn't a fan of Land Rover decals but they look 'right' on that colour and configuration.
Post #568580 4th Oct 2016 12:50pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
One to keep as it is.
Get that chassis treated, and look after it, there won't be many around like that in years to come. Wink 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #568582 4th Oct 2016 12:54pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Nice looking truck Thumbs Up
I'll look forward to seeing how this progresses 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #568586 4th Oct 2016 1:12pm
Love the graphics.
Post #568670 4th Oct 2016 8:12pm
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
Great! Thumbs Up
Stephen.
Post #568703 4th Oct 2016 8:58pm
alpacaman
Thanks for all the kind words. Gordon (for it is now he) did his first run to the animal feed merchant this morning. Starting to get used to the gearing. Didn't have much time to get out and start looking at which jobs I want to tackle first, but have decided that I definitely want to keep him as original as possible, just perhaps with a few select/tasteful mod cons to make the owning experience a bit more pleasurable. I think new door and window seals will be first on the list.
Post #569524 8th Oct 2016 6:01pm
g-mack
pffft! daft name!!
Wink My 109 thread
my youtube channel
Post #569540 8th Oct 2016 7:54pm
Cupboard
I like Land Rovers like that.
The only thing I don't like is that they tended to come with 205s and you're better off with 7.50s.
Where about in Norfolk are you? There seem to be a reasonable number of forumites around here.
Post #569551 8th Oct 2016 9:05pm
alpacaman
Why do you say I'm better off with 7.50s Cupboard?
I'm just south west of Norwich, off the A11. If there are ever any local meets I'd be up for coming along (although I'm out of action until the end of November now).
Post #569646 9th Oct 2016 3:26pm
Cupboard
More ground clearance under the diffs, lower rolling resistance. Better on and off road.
They were standard on the 110s of that age but not on the 90s for some reason. They only became standard on the 90s a bit later on.
The other good thing about 7.50s is that a lot of people don't like them so (at the moment at least) you can get
nearly new takeoffs for a sensible amount of money. I was looking at repainting my wheels and getting a new set of tyres but it worked out cheaper just buying a whole new set of someone else's wheels with tyres already fitted.
Post #569686 9th Oct 2016 5:35pm
alpacaman
Thanks. I'll definitely be wanting to paint my wheels, so I may well end up doing the same in that case.
Post #569688 9th Oct 2016 5:37pm
