Home > Td5 > Tinkling/rattling sound when taking foot of the gas at 70-60 |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 220 |
Gearbox? I've had the same thing, noise, decelerating from speed after the box had got properly warm.
Seemed to me that the bearings were rattling. So I ignored it ... on the 2005 truck these last 3 years and 20k miles driving to and from Switzerland in 30C for 12 hr at a time with the whole centre tunnel glowing red hot (more or less ) ... and it's still going fine. Drive it. When (if) it stops, fix it Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
2nd Oct 2016 10:06pm |
Might not be but check the heat shield by the turbo, they often fracture around the fixing points.
2nd Oct 2016 10:12pm |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 723 |
Check the thin metal heat shield on the passenger side gearbox mount. I had what sounds like a similar tinkling sound to what you have described, which happened at certain engine RPMs, and it turned out to be this little metal heatshield which is designed (I assume) to protect the rubber mount from the exhaust temperature. You can easily bend it, so see if its able to rattle against any metal parts.
3rd Oct 2016 11:08pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3467 |
I have this noise. Watching the thread with interest. Same speeds too. 1951 80" S1 2.0
4th Oct 2016 12:46pm |
Ken B Member Since: 17 Dec 2013 Location: Essex Posts: 106 |
+1 same noise and cannot identify where it comes from, it only occurs when lifting off the accelerator at 65+ ish mph Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape. If it doesnt move and it should: WD-40. If it moves and shouldnt: duct tape it. |
4th Oct 2016 8:57pm |
TechnoTurkey Member Since: 25 Jul 2016 Location: Worcestershire Posts: 88 |
+1 again for a similar noise when easing off at high speed, only happened a few times though.
5th Oct 2016 9:24am |
CamRSA Member Since: 24 Aug 2016 Location: Devon Posts: 66 |
Bizarre. 1hour drive today and always at the same speed when taking foot off the pedal.
8th Oct 2016 2:14pm |
