Home > Puma (Tdci) > Identify my oil leak |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 |
Hmm, anything under the bonnet? Vacuum pumps (run by the aux belt, right hand side when looking at front) are pretty common but not sure if that would run down and back that far.
3rd Oct 2016 9:05pm |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 |
Evening, I had a similar looking leak a few months ago, noticed a small patch of oil on the drive and on inspection looked very much like the picture in your post, I have extended warranty so my dealer traced it to a crack in the inlet manifold, so replaced and all sorted now Hope you get sorted mate.. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
4th Oct 2016 9:50pm |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
I had the same problem : a crack in the inlet manifold Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
4th Oct 2016 10:25pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16946 |
I would be rather concerned if I had that much oil in my inlet manifold!
4th Oct 2016 10:51pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2237 |
Thanks for your responses. I'm struggling to understand how it could be the inlet manifold, there should be no oil in there? Unless I'm missing something?
I remember on an old Rover I had there was a waterway that passed through the inlet manifold... possibly something similar? A quick google hasn't resulted it much... |
5th Oct 2016 10:24am |
Admittedly the oil leak on mine was nowhere near as much as Hanks, as I make lots of long journey's I assume the oil was getting thinner and making it's way out, technician said it was uncommon for this to happen.. |
5th Oct 2016 10:00pm |
Portafilter Member Since: 08 Aug 2010 Location: Melbourne Posts: 27 |
if its a 2.2 just above there is a small 90Deg rubber turbo hose. mine had a crack in it (and a loose hose clamp) and blew oil like that. didnt notice any air noise or loss of power either. The first time it split it blew a hole about an inch long in it, i noticed that.
9th Oct 2016 2:41pm |
Gaz Member Since: 18 Jan 2015 Location: Midlands Posts: 29 |
Wrong side for leak to be below the turbo methinks...Turbo is on the off side..That leak is on the near side..
Thats on Rh drive. Cheers |
9th Oct 2016 5:57pm |
post intercooler next to the EGR valve
10th Oct 2016 1:01pm |
