Home > Maintenance & Modifications > ** Update Returning ** -Fitting NAS style plinths
Page 1 of 3 123>
Stacey007
Hello
So I spent ages looking at all the different types, styles of lights... Finally decide on the 95mm NAS style. So order all the bits.
Had a quick look and the indicator light I checked the holes on the NAS plinth don't match at all? I'm tempted to cut the metal threads off and re drill the plastic to match the original holes? Is this my best option? The fog and reversing light should be ok and I've not checked the side lights yet.
what have others done? or should these fit the holes?
Post #567068 27th Sep 2016 6:05pm
That's an odd looking plinth Confused When I did this to my old 110 the plinths had holes in to take screws rather than studs:
Also, there's no hole for the light to fit through. Darren
Post #567071 27th Sep 2016 6:21pm
mk1collector
Take the bolts out and redrill the plinth holes to match up with the existing clips then either take the plastic clips out of the panel and use the bolts or use screws into the existing plastic clips. Ray
My build thread
Post #567077 27th Sep 2016 6:37pm
Stacey007
Seems the bolts are sunk into the plastic not as easy as just removing? as below
Could I hammer them out? or vice grip and twist?
Or should I just give these up and get these ones that should fit?
http://www.mudstuff.co.uk/defender-95mm-nas-plinth.html
Sad as I would be after 8 so a lot for 8 bits of plastic....
Post #567101 27th Sep 2016 7:30pm
Those are not OE plinths!
Post #567104 27th Sep 2016 7:43pm
mk1collector
These are a lot cheaper and MPs are great to deal with
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...SwHoFXtHD9
Personally I'd re adjust the ones you've got Ray
My build thread
Post #567106 27th Sep 2016 7:53pm
mk1collector
Also I've just noticed the plinths you have don't have any seals on the back so they will probably let lots of water in. Ray
My build thread
Post #567108 27th Sep 2016 7:55pm
Stacey007
Hello
I'm certain they are NOT oem, but I never bought them thinking they were, so no issue with that.
I've just had a go with mole grips and pliers and got the two bolts out... Smile
If I make a seal at the back or reuse the seals off my old lights do you think these are still usable or just get those other ones?
These came from this web site? bowers parts?
http://www.bowerspartsonline.co.uk/vehicle...over-parts
Thanks
Post #567112 27th Sep 2016 8:04pm
Buy some neoprene rubber or foam off eBay on a sheet, cut to size. Good seal and cost peanuts.
Your LED lights are waterproof anyway as a unit, the plinth is just a mount. Thumbs Up Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #567113 27th Sep 2016 8:07pm
Stacey007
^ Cheers (again)
I have some from my sound proofing but its 8mm... saying that screws tight guess it will squash up?
Another plug and play job that isn't..... Laughing
Post #567115 27th Sep 2016 8:13pm
leeds
They are cheap and very cheap dare I say nasty without getting slapped?
They are 95 mm plinths that are designed for other vehicles apart from Land Rover Defenders.
The correct OEM ones just screw from the outside onto the vehicle. No need to drill holes for the fixing studs, no need to grovel up on the inside of the vehicle to put a nut on. Which would be impossible if you have a wing tank fitted.
With the correct OEM plinth the connectors just pass through the hole in the middle of the plinth. With that plinth you will either have to drill out the centre of the plinth or mess around with the connectors.
My advice would be to buy the correct Defender NAS plinth.
Please note on the sellers website those plinths are described as NAS style not NAS specification
Brendan
Post #567120 27th Sep 2016 8:26pm
Stacey007
Brendan...
Your right, NAS style not NAS specification is the key.. hence the gaps are not correct. My Bad for not spotting that.
As far as Quality, the plastic I'm sure is no different to the 10 ones? its just a mold?
I will see how I go at adapting one of these, if it goes pear shaped then I will take your advice Smile
The lights fitting into these are sealed as Steve said, so it is just in affect a big plastic washer to hold them?
Post #567126 27th Sep 2016 8:39pm
leeds
Sorry Stacey but it is not a simple case that it is the same plastic as the more expensive ones
The chances are it is an injection moulding however just because it is claimed to be the same plastic does not mean that it is the same grade or quality.
The more expensive ones are ( yes am surmising from a previous life Razz ) made from 100% virgin material of the appropriate molecular weight. Cheaper components are likely to be moulded from material with a large percentage of reclaimed material, carbon black in etc.
Have a look at www.dont-get-burnt.com which is a comparison of material from the Australian Safari Snorkels and some of their copies.
In a previous existence we had to tell a company after some research that failure in their products could be simply overcome. Our advice was quite simple after 2 months testing. Conclusion was to ignore the accountants, buy a decent grade of polymer with known products and use a good injection moulding company.
Brendan
Post #567138 27th Sep 2016 9:00pm
Stacey007
Bow down I'm not going any further ^ You know your plastic
I will however see if I can get these to fit before I have a plan B (Bin them) Very Happy
I had a quick search on your site but could not see them? do you offer the correct ones?
Thanks again
Post #567149 27th Sep 2016 9:14pm
Stacey007
Hello
Decided over the evening and sleeping in it to return these,
Brendan's and others comments, I plan on keeping this truck so don't to be drilling new holes, making up gaskets and doing a botch job. These were cheap compared to actually NAS lights but not what I call Cheap Cheap (170 order)
So I e-mailed the company last night and this moring, an de-mail saying please return them for a full refund no quibble.
Happy all round (except I will have to wait longer to have LED rear lights now) Very Happy
Thanks for the Advice Brendan and others, your knowledge is Bow down
Post #567220 28th Sep 2016 8:07am
Page 1 of 3 123>
