Home > Td5 > TD5 alarm / immobiliser system |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
Probably easiest to buy a s/h loom with what you require as due to low spec its unlikely that plugs are actually there. Remove dash and find out what you have.
25th Sep 2016 6:53pm |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 |
OK, makes sense. When I remove the dash though, what am I looking for? 1998 110 300Tdi White Hard Top
25th Sep 2016 7:21pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
See a similar titled thread also in the TD5 section just below yours.
All the connectors should already be in the loom. As a minimum you will need 2 remote fobs. The alarm LED is part of the speedo. No point changing looms. 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
25th Sep 2016 7:23pm |
my 2003 looked to have no alarm or immobiliser fitted or set to start with but behind the dash 10AS green alarm unit fitted parts below, back door switch and wiring and programming
YWK100130 - SOUNDER UNIT BURGLAR ALARM WITH BATTERY BACK UP [ (V)XA159807 - ] (moved from Stansted position) AMR2022 - SWITCH-CONTACT-BONNET BURGLAR ALARM [ (V)TA977525 - ] ABU710170 - SWITCH & BRACKET ASSEMBLY-BONNET BURGLAR ALARM [ (V)1A618334 - ] AMR4893 - TRANSMITTER PLIP BURGLAR ALARM 433 MHZ [ - (V)YA184647 ] YWC102900LNF - SENSOR ULTRASONIC [ (V)TA977525 - (V)5A701968 ] AMR4897 - COIL-ENGINE IMMOBILIZER [ (V)TA977525 - ] Last edited by dorsetsmith on 25th Sep 2016 7:56pm. Edited 5 times in total |
25th Sep 2016 7:33pm |
10AS green alarm ecu was fitted to every td5 as standard, even if no functions of it are enabled, it is still needed by the engine ECU. The alarm ECU also controls the interior light.
1. Get two fobs 2. Get bonnet switch and bracket 3. Get passive coil for ignition barrel 4. Get garage or someone with a Nanocom to program fobs and activate functions. 5. Use 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Last edited by rallysteve on 25th Sep 2016 9:39pm. Edited 2 times in total |
25th Sep 2016 7:37pm |
Cheers, I shall look into all this and hopefully enact on it. 1998 110 300Tdi White Hard Top
25th Sep 2016 9:25pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1333 |
Why not fit an aftermarket alarm. I paid £140 for a Scorpion supplied and fitted to my old escort. Worked perfect. And was a good alarm & immobiliser
This was the one. https://www.ebay.co.uk/itm/290387868018 |
25th Sep 2016 10:12pm |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 157 |
You can add cdl to the lot by installing a relay into the 10as.
This allows for you to tap pin 2 and 3 to drive the locks. Nec ep2 3n1s is what you need. Hardest part is opening the 10as box. I've done the entire project on a farmer spec 2002. Volumetric sensor, back up sounder and bonnet switch optional. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
15th Oct 2016 10:51pm |
