Home > Technical > Rubber grommets for safari snorkel holes |
Rodney-too Member Since: 04 Jun 2016 Location: Cornwall Posts: 62 |
I did the same; as the holes have rivnuts I just put the bolts back in, with some copper slip to stop corrosion, and have left then in. Wth all the rivets and spot welds dents, it doesn't look too bad. Will get a photo when it's not dark!
14th Sep 2016 8:26pm |
sjwdrew Member Since: 31 Aug 2016 Location: London Posts: 18 |
Hi,
Did you remove it via the wheel arch? Also what is all this about drain valves? Simon |
20th Sep 2016 10:35pm |
Sorry for the delay; mine is an OE RAI so attached using 2 rivnuts in the wing above the air vent, so could be removed from the front. I have left the rovnuts in for now, as I need to get the wing resprayed where the RAI has rubbed the paints and primer down to bare metal!
Drain holes? Probably some in the air Box? Out of interest, when I removed the RAI the bottom of it was full of water! |
23rd Sep 2016 7:46pm |
