Home > Td5 > Td5 no go past 70 |
oakworthboy Member Since: 01 Nov 2015 Location: keighley Posts: 7 |
Performance is fine lower down the Rev range, I tried to go round a bus earlier in 3rd, did the same at higher revs.
12th Sep 2016 8:12pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
I don't know if it's worth looking into a rolling road so they can diagnose it. Changing parts can get expensive.
I've found sometimes it's better to bit the bullet and get a specialist to check it out. I tried changing all kinds on a motorcycle a few yrs back trying to get it to pull on the motorway. It turned out to be a fault rev limiter in 3rd onwards. I changed carbs and coils several times in a effort to sort it. A rolling road had it done in less than 30 mins 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
12th Sep 2016 8:31pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Do you have a way to measure the turbo pressure?
Does it get to high and the ecu goes in limp home mode? Or does the pressure drop suddenly? Then you could have a hose problem. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
13th Sep 2016 7:39am |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 157 |
clearing all the fault codes first and have a run again.
I've seen that happen on the few of the Td5s that i touched. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
23rd Sep 2016 12:00pm |
