Home > Td5 > TD5 Clutch Pedal Mod |
Mine does the same, and I can't seem to fix it An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
30th Dec 2014 5:31pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
I've tried copper grease, silicone etc, but it still creaks.
There must be an easy cure? |
30th Dec 2014 6:12pm |
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 |
Since there has been loads of defenders doing this mod, has anyone found a cure to this creaking noise yet because for purely selfish reasons I need to know as I'm thinking of doing this Saturday 2005 TD5 90 CSW XS |
31st Dec 2014 7:22pm |
DefenderJon Member Since: 01 Dec 2012 Location: Sunny Ulster Posts: 68 |
To cure the creak, you need to go in from the top of the pedal box. Open the bonnet and remove the six screws that hold the plate onto the pedal box. Remove this and lubricate the pivot point of the pedal. I used GT-85 on mine. Steer clear of silicon based lubes due to the close proximity of the clutch master cylinder seals.
I did mine a few months ago. Not a squeak since. Jon. Defender 90 TD5 CSW - The longer I own it, the newer it gets!! |
31st Dec 2014 9:08pm |
Thanks DJ, that's my first job of 2015 booked in!
I only gave the new spring itself and the plastic nipples a smear of grease and it had little effect. Cheers for the advice. Paul |
31st Dec 2014 11:01pm |
^^^ Well I tried greasing everything but after a couple of days it started to creak again and drove me mad, so I've taken the new spring out and gone back to the old spring, harder on the left leg but doesn't drive me round the bend now.
8th Jan 2015 7:59pm |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 218 |
Well.. thanks to Green Machine and Andy Jeff
My co driver at 57 kg and with grandkids - she didn't find stop start traffic a lot of fun Had a kit from Britpart a year ago as part of a prize. So eventually in sunshine ... followed the experts on this excellent froum took out carpets. levered off old spring, had a cup of tea Britparts two rubber bushes clip in no problem. Also the U shaped bush into the clutch pedal. (Followed the tip, use a bit of wire to pull into place) Fit the spring, compress pedal and wedge. The first side of Britparts new spring can be levered into the bush reasonably easily - but the second - I had to 'bend' the end of spring round the metal eye on the clutch pedal arm that was the location of the old spring, and just graunch the second side of the new spring into it's location. Multiple goes, made a heap of a mess of the rubber bush that second side. But I think it will stay in place and be a happy little spring. Unlikely to rattle out, the ends of the spring stick well thro the bushes/holes. Result - much better clutch. Thanks again to this forum. Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
25th Aug 2016 12:09pm |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
As per ppad above, I'm having a lot of hassle trying to force the spring back to get it into the second bush. One side ok, the other near impossible! Result is I've abandoned it just now, will try again when I feel I need a bit of a challenge. Looking forward to Mrs R being able to drive the motor. Just a note, it didn't feel much easier to push down once I'd removed the original Spring, how does the new spring make it any lighter?
11th Sep 2016 5:58pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 901 |
Be sure to fully depress the clutch pedal and hold it in place with a pole or some such device. Put all bushings in place and hook the loop onto the back of the clutch pedal and then pop the two top parts into the round pushings. Should take about five minutes. Without depressing the pedal and holding in place its nearly impossible. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
12th Sep 2016 2:30pm |
Yep, had the wife pressing the clutch pedal down while I tried in vain to attach the second side of the spring. I'll give it a go later in the week again, everyone else seems to have had little hassle with it, it must be do-able. I'll post if and when I get it in...........
12th Sep 2016 10:53pm |
stickyyates Member Since: 03 Sep 2015 Location: notts Posts: 11 |
Did mine by pulling the spring right up on both side with zip ties which made it very easy to fit
Once fitted I then just snipped the zip ties and it was done Took about 10 minutes once I had figured how to do it Hope this helps |
12th Sep 2016 11:07pm |
Here a link with decent pics. Good luck!
https://www.landyzone.co.uk/land-rover/how...od.275758/ 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
12th Sep 2016 11:27pm |
simon67 Member Since: 18 Jun 2015 Location: west sussex Posts: 569 |
Took the parts to my local independent and they reckoned they had to take the whole clutch pedal out
Anyone near Worthing who could us do it myself? PM gratefully received Simon |
13th Sep 2016 8:56am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2259 |
You don't need to take out the clutch pedal!
The job is made much easier if you release the pedal from the master cylinder threaded pushrod by removing the nut. This enables the clutch pedal to go a fair bit higher than it normally does, and the spring is then much easier to fit. |
13th Sep 2016 8:56pm |
