Home > Td5 > Intermittent brakes and charging |
Freddie Member Since: 21 May 2014 Location: Cape Town Posts: 46 |
Hi Everyone,
Forgive me; I have trawled the internet for answers, and although there is lots of info out there on this topic, none that I have found seem to help. Before I spend a small fortune on a new alternator/ vacuum pump, I was hoping that I could pick your brains... A few months back, I posted on the forum that the brakes on my 2004 Defender TD5 being less than useless. http://www.defender2.net/forum/post469358.html I needed to replace pads, disks, callipers as it was but with little effect. I then replaced the brake master cylinder and servo. Since the new cylinder and servo, the brakes have been MUCH better. However, they are intermittent. When I am going uphill (at high rpm), the brakes are sharp and fierce, with very little pressure that needs to be applied to the pedal to slow the car. However, there are times (e.g., sitting in traffic) when I apply the brake, and my foot travels further than normal before the vehicle slows at a comparable rate. More often than not, removing my foot and placing it back on the pedal (once) makes it sharp again, but this can be rather disconcerting. I have bled the brakes best part of a dozen times (no exaggeration) There doesn't seem to be any leaks or corrosion in the piping. The wheel bearings all seem to be fine. If the vehicle is stationary (and off), I get about six pumps through the brake pedal before it goes hard. If I then start the car, while applying gentle pressure to the pedal, it doesn't move. However, when I release my foot and place it back on the pedal, it feels as it should. I have removed the pipe from the servo itself, and there seems to be good suction. It feels the same as another Defender TD5 (with good brakes) that I used for comparison. (both vehicles are international spec / don't have EGR's or EGR piping) I cannot hear or feel any suction leaks in the servo piping either. This, therefore, has me completely stumped and wondering whether the vacuum pump is on its last legs? It is my understanding that the vacuum pump is part of the alternator on the TD5's? Coincidentally, I have noticed that my batteries are always fairly low on power: When off, they sit around 12v. On ignition (fuel pump running), it dips to 11.8v. Then on idle, the vehicle can be anywhere from 14.04v-14.50v which seems very erratic. The other TD5 that I checked, using the same method as above, was, Off @ 12.39v Ignition @ 11.8v Idle @ 13.9v I'm at a loss. Any help or suggestions would be greatly appreciated! Many thanks in advance! |
6th Sep 2016 1:29pm |
Many thanks for the reply Gazman!
I've just replaced the internals of the master cylinder with a kit. I knew that I should have purchased the entire unit when I placed the order. That said when I got it apart everything looked to be in great shape, no obvious signs or wear on anything. Nice fit - couldn't be better. The fact that the brakes are good 9 times out of 10 is what gets me. When the vehicle's revving high there's never a problem but freewheeling downhill the pedal is nowhere near as responsive. crazy! |
6th Sep 2016 6:11pm |
