Home > For Sale & Wanted > 110DC TD5 XS (2004) Overland Prepared pic heavy |
GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499 |
Advertising onbehalf of a customer if you are interested please PM me your contact details and I will forward these on, thank you.
No longer FOR SALE: LANDROVER DEFENDER DOUBLE CAB 110 XS TD5 85000 Miles Expedition Ready drive away with everything you need, and more! First Registered 2004 – Standard Double Cab XS Specification Utility Vehicle Re-Engineered and modified for Overland Expedition Vehicle 2012 A 12 Month MOT will be provided, current MOT expires Nov 2016. Central Locking: Electric Front Windows: Heated Front Seats: Air Conditioning Service History provided with receipts for modifications and supporting documentation. Security: Tracker fitted, LR OEM Alarm Immobiliser system; Gear Lever Lock; HD Wire loop with padlock to secure steering wheel. Safety: Full External Roll Cage with access ladder and side brackets for Oz Tent; all constructed to Safety Devices standards with SS fixings to chassis; 4 x Roof mounted Roo Spot lights with protective covers. 2 bull Bar Mounted Terra Firma Driving Lamps with protective covers. HD Rear quarter bumpers, Jate shackles, Front HD winch bumper: Safety Bull bar with fitted driving lights. Goodwinch TDS 9.5i Goldfish Winch fitted with Dyneema rope c/w remote wireless actuator Underneath: Full under body wax oil protection by Chris Parkinson Before and After Specialists; Diff guards, Steering guard. Wheels & Tyres:6 x Blindo 16 x 7 wheels with Cooper Discoverer ST Max Tyres (2 Spare Wheels) carried inboard. Suspension: Heavy Duty Terrafirma Springs and Shock Absorbers fitted with Original Poly Bushes all round. (not generic copies) Running Gear & Brakes: Standard HD Axles with diff protectors, new OEM hub bearings & seals, brake discs, callipers & swivels, SS Goodrich Brake Lines; Brake Fluid upgrade to Dot 5.1 for heavy overland use. ABS module unit overhauled and new pump fitted. Steering: HD Drag link with new track-rod ends, HD Terrafirma steering dampener; full steering protection plate. Transmission: New original VALEO Flywheel with complete clutch assembly and slave cylinder. Transfer box modified with Ashcroft high ratio gear cluster for better cruising speeds and economy. Clutch pedal modified to reduce pressure required to activate. Engine: Modifications include, new high capacity Allisport intercooler with silicon pipes, new water hoses belts and perishables. K&N air filter, Southdown Raised Air Intake. OEM new fuel control valve, injector wiring harness, cam cover seals, acoustic blanket with under bonnet insulation. ECU upgrade by Alive tuning giving 175 BHP with greater economy. All sensors cleaned and tested. Electrics: Twin Optima Batteries with Intelligent Battery System (IBS) dual battery and condition monitoring system; RING POWERSOURCEPURE 2200 W Pure Sine Wave Inverter; Rear lights modified to NA Specifications. Rear compartment LED light fitted. 12 V Water Pump and 12 V fuel transfer pump. Additional 12V sockets in cab and rear compartment. Dual fuel Fridge will run on Gas, 12V DC Electric or 240V A/C Electric. High level spot lights, rear work lights. Fuel Tank - Increased Capacity: Standard Fuel Tank removed and pressure cleaned internally, new OEM fuel pump installed and tank re-fitted with new in line fuel filter. Hatch installed in truck bed to access the fuel pump without removing the tank. Special locking fuel cap flap fitted. Auxiliary 60L fuel tank fitted with 12V DC transfer pump, hose and discharge trigger. Spare Parts Kit: Alternator, starter motor, wiper motor, water pump, viscous fan assembly, hub bearings & seals, one shot swivel hub grease, fuel filter, oil filter, rotor filter, sump washer, top and bottom coolant water hoses, thermostat housing, crank sensor, top gasket kit, manifold gasket kit, alternator drive belt, assorted fuses and light bulbs Accessories: NANOCOM Diagnostic System; VAIR 12 DC compressor; CB Radio; High lift jack: HD air bag: Tyre repair kit; First aid kit; Camping Gear: Maggiolina Roof Tent with access ladder & awning; wind up handle & mattress; Oztent RV2 with awning; ARB 2500 fixed Awning; Camping Table, chairs, cooker, gas bottle. In the Cab: The cab is soundproofed and currently designed for two persons, it is fitted with OEM A/C system; two front seats are raised, heated and fitted with washable waterproof covers; rear seats have been removed; a cabinet system installed with drawers and cupboard all with HD magnetic catches; a fridge is mounted behind the passenger seat providing access at all times. (the rear seats will be supplied with the vehicle, they can be re-fitted if required by removing the cabinet system) Rear View Camera, platform for Sat Nav; compass. Adventure isn't paved! Last edited by GSLRO on 28th Sep 2016 8:10pm. Edited 4 times in total |
27th Aug 2016 2:33pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6485 |
Thanks for buying an ad 1988 90 Td5 NAS soft top
2015 D90 XS SW |
5th Sep 2016 1:52pm |
Cheers Martin Adventure isn't paved!
5th Sep 2016 7:41pm |
