Home > Maintenance & Modifications > How do you remove.... |
There was a discussion on this topic updated not so long ago for the puma/TDCi, had pictures'n'all, try searching?
If I recall it's a pull, but I'm not 100% on that! Solved the bowel problem, working on the consonants... |
27th Aug 2016 10:42pm |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2872 |
Pull, mind you don't knock your teeth out though.! Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
28th Aug 2016 9:17am |
Martyn Member Since: 10 Feb 2011 Location: Stourbridge, West Midlands Posts: 151 |
Aghh thought so. Will crank the pulling up a few notches as she won't budge.
28th Aug 2016 10:39am |
http://www.defender2.net/forum/topic14602.html If you go through life with your head in the sand....all people will see is an ar5e!!
28th Aug 2016 11:55am |
