Home > Td5 > Nanocom readings
excossack
Nanocom readings
Having had a quick play with the Nanocom first thing was to check the MAF, this was giving a reading of 52 or 53 at idle, which I think is correct?
Turbo boost was getting to around 1.7 I think while accelerating
What are good figures for cylinder balance?
Did spot the ECU appears to think the T/C is in Low box (its a disco box with out the hi/low switch)
So think I need to look at this.
When in high range I assume the switch would make contact? and then when not in contact the ECU assumes low box is engaged? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #557161 19th Aug 2016 9:19am
Nanocom. Plug-in worry Laughing
Post #557181 19th Aug 2016 11:27am
excossack
Thanks! 1999 Defender TD5 110
Regards
John M0VAZ
Post #557182 19th Aug 2016 11:28am
Sorry, not helpful I know!
People I know who plug them in, are constantly monitoring and worrying about stuff they never knew about before and their truck has always run fine (and since)!
Ignorance is bliss.
Post #557187 19th Aug 2016 11:35am
excossack
Not worried, just want to make sure the reading is correct i.e for the MAF and want to understand what the cylinder balance is all about. 1999 Defender TD5 110
Regards
John M0VAZ
Post #557189 19th Aug 2016 11:41am
I've no need talk really. I drove from Northwich in the heat yesterday afternoon and thought the 110 was down on power a little. I thought I should unplug the MAF to see if it made a difference.
A nanocom would of course give me that info, but i just put it down to 'warm air' and spannered on the v8 instead Shocked
Post #557192 19th Aug 2016 11:50am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
AFAIK, your MAF reading seems correct to me.
Cylinder balance, I think they should all remain within the same values, ie not one going completely off range. These can fluctuate, but should remain in the 1 digit value range (either positive or negative) when idle.
TB low range input, might very well be a software bug in the Nanocom, dunno if it's been fixed in a recent update, see the Nanocom forum for more info. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #557204 19th Aug 2016 12:47pm
roel
I have a very old nanocom. the gray box thing and almost all switches are just the oposite from what I would expect. Mr. Green
Your Maf reading is about right it might be a little higher, but your 3rd gear full power with high revs reading is more important, just google what it should be.
cylinder balance with mine is max about 4 when running constant. If I am correct the balance is about trying to let the engine run smooth so the ecu varies or the timing or the amount off fuel it injects.
Your turbo pressure is high for a Td5, so your is probably tuned. Mine peeks at 1,25 in normal mode and 1,35 with my psi power box switched on. Roel
2003 90 Td5 (2009-now)
Post #557271 19th Aug 2016 6:32pm
excossack
I do have a mild Stage 1 tune Smile not as noticeable now as it was when I got it done, but I guess I am used to it.
Will google for 3rd gear revs. 1999 Defender TD5 110
Regards
John M0VAZ
Post #557276 19th Aug 2016 6:59pm
Screbble
I too am in the if it ain't broke don't fix it camp - ignorance can be bliss - but ignorance in my case tends to cost money Rolling with laughter
That said, I do think a Nanocom would be a sound investment - albeit I would end up looking for things.......
John, how are you finding it? Are you guilty of now looking for things or is it something you have under control?
I must say I am tempted to buy one but I know how that story would end Laughing
Post #557722 21st Aug 2016 6:02pm
excossack
I am finding it OK. Only used it once while driving, a bit hard to look at the readings while driving.
I have a 2hr ish trip on the cards next weekend for a rally, so will be towing up and down hills and low rev work, so will be taking it with me and mate can watch the screen and see how things look.
My main reason for getting it was to make sure all is well and keep eye on things and to make sure sensors are good i.e MAF being one.
Once I get an idea what figures should be then I will be content, but for now I will be playing with it a bit!
Trying to register with BBS as a new owner and awaiting a reply back. Then will look at latest firmware etc if needed.
Another reason for buying it, if i want to get the car checked then it will cost in the region for 30-40 to get scanned, or more if paying local garage fees, now I can do it myself. 1999 Defender TD5 110
Regards
John M0VAZ
Post #557732 21st Aug 2016 6:41pm
Screbble
Good man Thumbs Up
Thanks for the response - yes I agree with the preventative maintenance aspect.
According to a DJ earlier, it's only 18 weekends until Christmas (I know Rolling Eyes ) so maybe Santa might bring me a Nanocom Thumbs Up
Post #557761 21st Aug 2016 7:58pm
excossack
Maybe worth jumping on the group buy deal and getting one earlier and maybe saving some money with the offer? 1999 Defender TD5 110
Regards
John M0VAZ
Post #557815 21st Aug 2016 9:02pm
Screbble
Thanks for pointing me in the Group Buy direction John - I may just take the plunge Thumbs Up
Of course you are forgetting that Santa does not have to but his presents, his elves make them......
Post #557893 21st Aug 2016 11:52pm
Screbble
Please read 'buy' not 'but' ^^^^
I might get a pair of reading glasses off Santa too Laughing
Post #557894 21st Aug 2016 11:53pm
