Home > Td5 > exhaust bolts |
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 78 |
Hi, I did the same swap with mine recently.
I can't remember the size of the bolts but as they bolt straight through once the old bolts are cut out its not that critical. If you are reusing the rear section and cutting the old bolts out you will need to be careful with the angle grinder. I thought my rear section was ok but the flange was heavily corroded and it was just starting to crack behind the weld. I always use a light application of exhaust paste just to ensure a good seal. The front seals on a ring which is part of the cat pipe and doesn't use a gasket. The rear has a metal gasket which is widely available. The only advice I would pass on is to loose fit it first and check the clearances are all ok. You can adjust how the pipes sit by the angle you bolt the front joint up at. On mine the cat was pulled too close to the chassis rail until it was adjusted. Hope this helps. Defender Td5 Commercial 2002 Discovery 3 TDV6 HSE 2005 Discovery 4 SDV6 Landmark 2016 |
10th Aug 2016 1:37pm |
Click image to enlarge |
10th Aug 2016 8:58pm |
yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230 |
Thanks guys
10th Aug 2016 10:20pm |
