Home > Td5 > Rear replacment LED fog and Reversing lamps
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I want to replace the rectangular fog and reversing lamps for round ones. I'm thinking LED types. Any recommendations? I've found ones from Britpart, Wipac and Wipac NAS. Are these any good and whats the difference between the UK and NAS standards. Can both be used here?
http://www.paddockspares.com/catalogsearch/result/?q=led+reverse Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #552976 2nd Aug 2016 1:18am
Screbble
Mine had the round NAS fitted as std, and I upgraded them to RDX LED's from Boltonbits (see Fleabay).
Similar price to those you have referenced and no trouble at all (RDX fitted all round).
Made quite a difference to be honest, but my originals were past their best.
I think there's plenty of general info regarding the various LED suppliers and their merits on here already.
Of course if you are trying to overcome the general poor output of the reversing lamp then it might be worth you fitting an additional 'pair' either side I.e. 2 fog, 2 reversing, or fit an additional reverse lamp above the door (relocating the rear washer). Plenty on here about that.
Just be mindful of legislation when tinkering with lights.
Post #552990 2nd Aug 2016 7:19am
I've searched high and low for oem look LED rectangular Fog and Reverse Big Cry
Post #552995 2nd Aug 2016 7:33am
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I also looked high and low as it were for rectanular led fog and reverse lights and came to the conclusion that if I really wanted LED then they would have to be NAS style round ones. Still like the look of the rectangular ones but I really cant complain about the performance of the Wipac LED ones. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #552999 2nd Aug 2016 7:53am
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
I had two of these fitted to the rear of my roof rack. They make amazing reversing lights Thumbs Up
Post #553010 2nd Aug 2016 9:23am
Those little Lazer (and larger) lights always get positive reviews.
I looked into aux reverse lights, there are legal wiring requirements and regarding use.
However, I never proceeded as I just didn't see the benefit worth the effort and cost to fit and mounting etc.
If you've got a pre existing cable run and mounting well then that just makes it easier, you could run wiring down to the front if you wanted to.
Post #553017 2nd Aug 2016 9:56am
Riverboy
Lazer make amazing lights. These are meant as work lights and have a separate switch on the dash, but they double up as great reversing lights when needed. I have to be careful where I use them though as they would blind everyone. Not a problem out here in the country though and saves me reversing into a ditch or off a mountainside. I have Lazer ST-4s and RS-4s plus a Triple R-24 on the front. It has to be seen to be believed, crazy crazy light. Thumbs Up The Triple R-24 also has a separate dash switch to keep things legal.
Post #553024 2nd Aug 2016 10:06am
CY88
1986 Defender 90 V8 Petrol ST Keswick Green
If you like things symmetrical, I’ve been really impressed with these dual LED units. Reverse is really bright:
Quite pricey though Sad and, unless you want to cut the bodywork, you'll also need the plinths and (in my case at least) a couple of large rubber o rings - see 3rd pic)
http://www.carbuildersolutions.com/uk/led-...nd-reverse
FFRR Supercharged - Series One - Defender 90 V8
Post #553025 2nd Aug 2016 10:10am
nakatanenga
Germany
Hi,
impressive!
Who did the tailgate conversion? WANTED:
SII or SIII in max 1.5k
Post #553062 2nd Aug 2016 12:28pm
CY88
nakatanenga wrote:
Hi,
impressive!
Cheers!
Purely Metal do the tailgate hinges. Pretty sure there was a little article about them in LRO recently.
Post #553072 2nd Aug 2016 12:45pm
Riverboy - Assume you have roof spots then? If so similar rules to here then regarding switching... Thumbs Up
CY88 - Interesting solution! Not seen those before, allow you to do the double up mod but not add extra units to the rear.
I wouldn't say they are particularly expensive, ordinary LED versions are about £25 each so if you wanted 4x of those..
Post #553076 2nd Aug 2016 12:52pm
Riverboy
Yes, well one Triple-R 24 on the front of the roof rack which when switched on will come on with high beam, however it's not road legal so has an on/off switch on the dash. Two rear ones only come on via their dash switch. The RS-4s and ST-4s are road legal so come on with high beam, although if I could do this again, I'd only have one pair come on with high beam because all four are a bit too much I think.
Post #553085 2nd Aug 2016 1:18pm
MC84
Great, thanks for all the info and advise, much appreciated. Time to shop!! Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #553134 2nd Aug 2016 3:46pm
rallysteve
MPS trading do LED versions of the TDi age reverse and fog lights: http://www.ebay.co.uk/itm/272226848080 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #553148 2nd Aug 2016 4:44pm
