Home > In Car Electronics > GPS Antenna |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
Why do you need to mount an external antenna for your GPS?
Mounting the GPS antenna low under the front bumper is going to give you all sorts of issues with lost satellites, interference from the engine electrics etc.... The rule for GPS antenna, and come to think of it, ALL antenna mounting is to get as high and clear as possible.. If you really want to mount one at the front, just pop a decent 3M sticky pad on top of the one you get, and use it that way... ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
1st Aug 2016 10:38pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
Thanks - long done now Mike
1st Aug 2016 10:54pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
What was the solution...?
Cheers Simon |
1st Aug 2016 11:21pm |
