Home > Maintenance & Modifications > Oil drain valve |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10360 |
I have one, made by Femoco.
Worth every penny if you do regular services yourself. Plus points: No oil can be blown by the wind to all around your drainer... If you do your servicing outside. No need to buy plug washers every time No need to fish the plug and plug washer from a tub of used oil No chance of fudging the sump thread Make sure you buy the optional hose |
24th Jul 2016 6:45pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila, SFO, Amsterdam Posts: 678 |
Thinking about getting this plus the units for all the gear boxes as well to make DIY work much simpler and cleaner. Sometimes the shops can get pretty busy for a simple oil and filter change...
25th Jul 2016 2:38am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2079 |
Worth every penny, makes changing the oil so easy.
Mo The Land Rover 90 - Many are called, few are chosen. |
25th Jul 2016 5:59am |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
I have one of this :
Femco Standard 90° Straight Drainer with hose 250mm https://www.drainplug.com/en/packages/stan...21-01.html Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
25th Jul 2016 7:48am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
+1 - great invention.
Installed mine after the 2015 oil change Made the 2016 oil changes so much better Worth every penny Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
25th Jul 2016 11:17am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5743 |
+2 from me. Makes it easier to drain in then event of overfilling 1999 Defender TD5 110
25th Jul 2016 11:45am |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 205 |
Thanks for all the replies, looks like the Femco one is added to the shopping list
25th Jul 2016 4:35pm |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
I have one too but not yet fitted as my local independent guy forgot to fit it on the last oil change! Ho Hummmmm Cheers Don.
25th Jul 2016 5:06pm |
