Home > Tdi > Front bumper removal |
yes 4 bolts not threaded into the chassis in to this
Click image to enlarge Last edited by dorsetsmith on 20th Jul 2016 2:18pm. Edited 1 time in total |
20th Jul 2016 2:08pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
Yes just the four bolts, but the nuts are not captive or welded into the chassis but rather slide into little groves within the chassis and are held in place with spring clip fasteners . For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
20th Jul 2016 2:12pm |
Wandathe110 Member Since: 10 Apr 2016 Location: Manchester Posts: 65 |
As above probably the most worried free part to remove
20th Jul 2016 2:53pm |
Cheshire Dave Member Since: 05 Jun 2014 Location: Chester Posts: 119 |
So do these pieces slide in from the front on the chassis ? I suppose I'll know when I undo them !!
Dave |
20th Jul 2016 4:58pm |
Click image to enlarge slide on to the bumper red arrows Click image to enlarge |
20th Jul 2016 5:13pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
20th Jul 2016 8:11pm |
Thanks guys I'm with it now.
Even I should be able to manage that ! Dave |
20th Jul 2016 9:17pm |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1168 |
Did you manage?
I removed my winch bumper to fit recovery points and was only able to get half of them back into place Still haven't had a chance to have another attempt at it My confidence has been writing cheques that my abilities can't cash for years. |
3rd Aug 2016 11:16pm |
cypermethrin Member Since: 15 Dec 2010 Location: Berkshire Posts: 84 |
You say that is the easiest part to remove but it still took 40 mins to get the old bolts out...
5th Aug 2016 5:56pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16894 |
When I bought my Defender the 4 bolts were simply dropped into their holes and not screwed into anything!
They've now got nylocs on them, it is possible though fiddly to use normal nuts instead of the nut plates. |
5th Aug 2016 7:57pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10363 |
No bolt on a Defender is ever easy!! Try removing the rear seats from a pre Puma SW....if you're lucky, they'll snap on the first turn.
5th Aug 2016 8:28pm |
never mind that try the one in the seat box 4 hr to get two m6 bolts out from B pile
cutting disc in end |
5th Aug 2016 9:41pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 720 |
Getting the bolts back into the plates can be the hardest part. Fiddly lining up the holes.
6th Aug 2016 8:48am |
I probably matched that with them, I even went machine mart to buy an air chisel!!! Which didn't work either! |
6th Aug 2016 11:29am |
