Home > Maintenance & Modifications > 4 point internal vs 6 point external SD cage |
BCdefender Member Since: 26 Oct 2015 Location: Nanaimo Posts: 211 |
Hi,
I am trying to get a grip on the difference in protection between the safety devices L255 4 point internal cage and the L242 6 point external cage. The 255 seems great for the middle row but I'm just wondering how much protection the front row would get. Thanks a lot. 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
18th Jul 2016 6:54am |
Option 1: http://www.safetydevices.com/expedition/pr.../843/1089/
Option 2: http://www.safetydevices.com/expedition/pr.../643/1810/ Thanks 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
18th Jul 2016 3:42pm |
Not sure if anyone has been following this but I have received some great advice from some others on this site who say the internal cage should be paired with a front external cage. It essentially creates a partial or half cage for the front which is compatable with a rack. 1999 Defender 110
19th Jul 2016 11:20am |
The internal 4 point and an external front roll hoop is the way I intend to go eventually but I'd like some better picture of where they bolt to the chassis/body and how much room they take up. Also on this side of the pond insurers don't like roll cages as they think you are racing the vehicle Ray
19th Jul 2016 12:11pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3334 |
With regard to the insurance, mine covered it without raising the premium.
19th Jul 2016 1:37pm |
steve_c3 Member Since: 30 Apr 2015 Location: Hants Posts: 171 |
^^ My insurance was very low too. APlan didn't mind any mods including remap, snorkel, roll cage etc.
I had the L148 in the end and must say I was surprised how little space inside was taken up. Couple of the usual SD ad snaps below: Click image to enlarge Click image to enlarge Plenty of padding added now too! Click image to enlarge 2002 Defender 110 CSW TD5 |
19th Jul 2016 2:13pm |
Wow this is exactly what I had in mind
Does the exterior portion of the cage bolt back onto the roof or does it somehow connect to the internal portion of the cage? Any issues with leaks? Did you use the SD padding or something else? Thanks! 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
19th Jul 2016 4:07pm |
tmichel Member Since: 23 May 2016 Location: Oberhausen Posts: 7 |
Hi,
I got a similar cage on my Puma DCPU, front external / rear internal. The front part is bolted to the inner part through the roof, I have no problems with leaks so far (mounted for a year or so now). I used SD padding on most of the inner part to get it approved by German TUV (similar to MOT). Regards, Tom. |
19th Jul 2016 9:48pm |
As tmichael says, it bolts throuh the roof and there is a plate each side. I assume there is a gasket or sealant of some kind as no leaks yet. Touch wood.
Got the SD padding and 7 lengths did the areas they suggest (shoulder height and above). Very happy with it so far 2002 Defender 110 CSW TD5 |
19th Jul 2016 9:55pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7876 |
Steve-c3 your external front bars go over the top of the roof to the B post, where as I notice most go along the side to the B post, was this just your choice? I'd be keen not to add height to the roof.
Did you get it fitted at Mildenhall? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
18th Oct 2016 1:27pm |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
Just as an aside, I have just ordered this one: -
http://www.safetydevices.com/expedition/pr.../656/1805/ I was thinking of going for the 6 point short one that goes up to the C post but carry at least one dog a lot of the time and couldn't live with myself if my skimping a couple of hundred quid on protecting his compartment meant he suffered. Apparently quite a faff to install and i'm going to fit the optional B post diagonals if I can make them fit, although the padding kit is over £500 so will be going the Demon Tweeks route. I'm not really looking forward to fitting it but it will make me a lot happier as to the crash-worthiness. |
18th Oct 2016 1:59pm |
Is it just the model that dictates the route of the front external cage to the B posts. When i look up SD Puma the bars are as shown below?
Click image to enlarge What'd the Demon Tweeks route? Will be interested to see it fitted Thon The link is for a cage to suit a 300tdi 110 94-97 but you're showing driving a 2.4tdci? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
18th Oct 2016 2:30pm |
I think (but i'm not sure) that the black 90 you show has a "cosmetic" front cage - not actually protective at all in the event of an accident.
The one I chose is specified for a 300tdi SW but as you will see in the pictures on their website is fitted to a Puma, which is exactly what I have. S.D. state that they don't recommend it because there needs to be a lot of interior trim changes/cutting in order for it to fit. However, it is the design I wanted so will happily sacrifice some bits of plasticky trim. They have sent me some marked-up pictures showing where the trimming needs to take place. I am more than likely just going to remove them as the load bed of mine is going to be further fitted-out for load carrying (dogs, guns, camping equipment, etc). The Demon Tweeks route is to use individual lengths of cage foam to protect the areas I want protected but not at such massive cost - Demon Tweeks is a supplier of all sorts of Motorsport equipment in the UK. I will of course post some pictures in due course. |
18th Oct 2016 2:54pm |
Thon, that's brilliant thank you. The cage you link is certainly a lot more robust than the internal cage SD show for a Puma.
I stole the photo from Twisted but it is a SD 4pt 'Style bar' which appears the same as the 4-pt roll cage just bigger tubing. I believe both are structural (when linked to an internal cage) but welcome corrections? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers Last edited by JOW240725 on 18th Oct 2016 3:21pm. Edited 1 time in total |
18th Oct 2016 3:16pm |
