Home > My Defender > Corris 90 |
Top work I think your right about the rusty mudflap brackets, the mrs just had all four of hers replaced under warranty on Friday Ray
2nd Jul 2016 6:35pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1751 |
She had a visitor today who just popped by for a spruce up
Click image to enlarge |
3rd Jul 2016 8:17pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10361 |
I hope you gave that zip tie a 'trim' !!!
7th Jul 2016 7:11am |
Trust you to spot that . And yes, I did ask myself why I took photo before going for the snip
7th Jul 2016 2:56pm |
Cake Member Since: 10 Jun 2015 Location: Essex Posts: 277 |
Great looking truck!
Best of luck with your undersealing - just undertook my own last weekend completing most of it and found it very rewarding and like everyone said you get very dirty! Just cover yourself in fairy liquid after and it comes off - also make sure you cover the ground around the car too quite a bit out or you get plenty of overspray from the cavity wax as I learnt the hard way |
7th Jul 2016 5:41pm |
Thankfully I'll be in a pit for the task that lies ahead. I've tackled it before on previous Defenders so overalls, filtered mask and spec's at the ready . It's the only day of the year I'm not a ginner
7th Jul 2016 7:59pm |
I'll bring the 90 up, it needs some anti corrosion treatment
7th Jul 2016 10:34pm |
anytime Steve
8th Jul 2016 5:54am |
The underside has now been treated and the corrosion prevention continued tonight.
Any body looking on would think I must be mad - window blocks removed, masking tape to underside of screen gutter and sealant in hand. Windscreen rubber sealed to surround and sealant applied to foam strip under gutter. Thinking about it - I am mad; I shouldn't be having to do this to a nearly new Defender |
12th Jul 2016 9:23pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3755 |
G'Day from Aussie.
What sort of sealant did you apply to the foam strip? Pickles. |
12th Jul 2016 10:17pm |
I use an MS polymer pu sealant which is a lot thicker than silicone. You will need to mask up the area as it is very sticky. Use a strong mixture of washing up liquid to smooth off.
13th Jul 2016 6:02am |
chrisbridgeave Member Since: 22 Feb 2016 Location: Lancashire Posts: 66 |
Very shiny Corris grey 90 you have there -and much nicer than mine - how do you do it?
13th Jul 2016 7:40am |
OK thanks, so it just sits on top of the foam & doesn't sink in like Mr Tolleys Sealer? Pickles. |
13th Jul 2016 9:48am |
That's correct, it doesn't sink.
@ Chris, I use various products in the cleaning process. When I first got this I washed using steam cleaner with a wash/wax through the snow foam gun, clayed using a Farecla mit followed by Farecla super resin wax and Farecla black top. I top up the shine with Greased Lightning showroom shine |
13th Jul 2016 11:30am |
