Home > Off Topic > Thermal stores
languedoc
Scotland 2008 Defender 110 Puma 2.4 CSW Alaska White
Thermal stores
It occurred to me that there could be someone on here that's a genius on heating systems. In particular I am looking at a thermal store for my heating and hot water.
I want to feed it from a PV system and 2 back boiler log burners.
House is pretty big at 400m2 on 3 floors and heating will be through radiators because the existing structure won't lend itself to underfloor.
I'd like to add a driveway heating system in a separate zone too.
Any advice would be great.
Post #545416 2nd Jul 2016 7:45pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Post #545533 3rd Jul 2016 8:18am
languedoc
Thats very similar to the ones i have looked at. I just need to find an actual person that knows how to fit this type of system in France.
After several discussions its very apparent that nobody nearby knows about them
Post #545553 3rd Jul 2016 8:59am
noworries4x4
As you are in France contact Pignon Gascon in Gers he does a lot of conversions into old places, air inverters ect ect, knows his stuff. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #545579 3rd Jul 2016 10:42am
steventheplumber
Would love to come and do it for you! But you may somebody closer on the expat sites. Good luck
Post #545580 3rd Jul 2016 10:43am
noworries4x4
While I was working with my friend at Pignon Gascon a couple of years ago we visited his local builder's merchants (makes B&Q or Jewsons look like a corner shop) and they had on display a set up that had the collector thermal pipes tied to rebar in the footings of the building and the output heating pipes in mats in the walls. I know this is not what you are specifically after but the French are just miles / kms ahead of us in green energy. If everything is under control you are not going fast enough.
No Worries 4X4
Post #545593 3rd Jul 2016 11:38am
languedoc
I've seen those before.
You can't drive more than a mile without seeing a merchants of some kind. Your friends company is nearly 4 hours away but might give them a call.
I know the specs and outputs needed for everything, have the system fairly well worked out but its the runs and installation I really want an experienced person for. My plumber wants to "have a go" which scares me. It's going to be a show system for potential clients so needs to be a tidy install.
Post #545605 3rd Jul 2016 12:02pm
steventheplumber
If he has not done one before would be best to be overseen by a competent person.
Post #545613 3rd Jul 2016 12:30pm
languedoc
Just need to find a specialist but the search continues.
My plumber is good but doesn't comprehend heat loss on runs and efficient installs. He can do wiped joints with the best though!
Post #545614 3rd Jul 2016 12:34pm
steventheplumber
We are not allowed to wipe joints anymore, just a distant memory know. Still have my mole skin though.
Post #545621 3rd Jul 2016 12:57pm
cecilthecat
We've just had our Plumber in France quote for fitting the following boiler including a 3000 litre heat store for the heating and a 500 litre one for the Hot water.
This is up in the Dordogne
http://www.hargassner.uk.com/our-products/...20kw-60kw/
Post #545945 4th Jul 2016 3:03pm
