Home > Technical > Abs and traction control lights |
jimsadventure Member Since: 10 Nov 2013 Location: edinburgh Posts: 199 |
Any ideas what this could be , I have a svx with 12000 miles on it in storage ,, I removed the rear splash guards from the back discs and since then bingo I have extra lights on the dash ! Maybe kinked a wire but they look fine on both sides
23rd Jun 2016 6:38pm |
Thanks for the reply Gav40 ,, how do you reset the gap ?? Does this happen when you drive it or by physically taking them out and resetting the gap ?? Are they just a push fit
25th Jun 2016 10:22pm |
Just a push/tap fit and they should be all the way home.
http://www.defender2.net/forum/topic20879.html?highlight=gap If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th Jun 2016 11:34pm |
Gav40 Member Since: 30 May 2015 Location: Maidstone Posts: 41 |
Hi, i use to have this trouble all the time after a days off roading, the mud etc would get behind the disc and push the sensor away from the disc causing the gap to be to large for the sensor to work and the traction control and abs would stop working and the lights would come on.
As said above the gap will correctly reset if you push the sensor fully home and go for a drive. |
26th Jun 2016 7:24am |
