Home > Off Topic > Cracks in concrete
leeds
Cracks in concrete
Have a concrete ramp about 900 X 750 x120
There are some cracks in it about 2mm wide.
What is best way of sealing the cracks before winter time and risk of ice cracking the ramp completely.
Brendan
Post #541573 19th Jun 2016 6:53pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
You could use something like this.
http://www.screwfix.com/p/sika-sikaflex-eb...00ml/79250 Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #541575 19th Jun 2016 6:58pm
chasthechippie
Ardex A46 most large Builders Merchants eg Sheffield Insulations now known as SIG
Post #541579 19th Jun 2016 7:05pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Resin anchor that is available in silicone type cartridges. Jewsons or RK fastenings. Thumbs Up
Post #541634 19th Jun 2016 9:26pm
AJC
We use a Resin that's designed for anchor bolts. Currently holding my chimneys on at home too. Very good stuff
Post #541650 19th Jun 2016 10:05pm
leeds
Resin anchor. OK have never used it. Have a couple of 'ground' anchors for the roller shutter door which will be going into newish 3 months concrete. Now the 'ground' anchor part is powder coated tube about 50-60 mm diameter. Would resin fix to powder coating. Also how much bigger should the hole in the concrete be?
So now trying to sort out two issues at the same time.
Brendan
Post #541652 19th Jun 2016 10:15pm
AJC
You don't have to use a resin fix. I find a 'throughbolt' better.
If you use an M12 through bolt. You drive 12mm diameter.
If you use threaded bar (M12) with resin, drill a 14 dia hole.
Post #541657 19th Jun 2016 10:34pm
