Home > Maintenance & Modifications > Entreq front mudguard extensions |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
SORRY! Brendan |
17th Jan 2011 4:52pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 980 |
Thanks, great info. But as mine are rotating, How do I fix?
Merlin |
17th Jan 2011 5:52pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16962 |
It works better if you put a washer between the nut and the rivnut before tightening. |
20th Jan 2011 5:20pm |
Sounds good, but the bolts on the mudflaps are rotating so I can't get the mudflap off so I can get the problem sorted. The mudflap is banging about so needs tightening before it disapears.
Merliln |
20th Jan 2011 6:44pm |
Try prising the bolt head down with say a screwdriver/pry bar putting pressure on the rivnut, then you might be able to undo bolt.
Hope that makes sense. Good luck. Brendan |
20th Jan 2011 7:24pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
A little feedback on the performance of these extensions. Run the Landy this week without the need to wash it The guards stop about 80% of the muck that used to obscure the drivers window and door mirror, the sides of the Landy are also a lot cleaner meaning I stay clean getting in and out of it On the whole I am glad I fitted them, once the rock sliders are fitted they should help some more as the brackets where designed with rock sliders fitted, but work almost as well without them.
Click image to enlarge It's mostly the bottom of the snorkel and a little of the drivers door. Click image to enlarge The drivers window and mirror are now clean Click image to enlarge Some spatter on the rear door. When you have left lock on you still get some spatter but no where near as much as I used to get |
23rd Jan 2011 7:03pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
Who shattered your passenger window
23rd Jan 2011 7:15pm |
Nobody, it's my neighbours rough cast
23rd Jan 2011 7:47pm |
I ordered a set of Entreq mud guard extension brackets on the 3rd February and received confirmation of payment, an order number together with a status of 'processing' against the order! Great I thought!
Since then NOTHING???? Despite an e-mail to Olaf requesting an update on Saturday! Impressed?? Not very!!! At the moment anyway! Lorryman any details how long you waited would be very welcome about now! Thanks Buddy! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
15th Feb 2011 10:21pm |
Ordered on Wed 5th Jan, and was delivered Tue 11th Jan |
15th Feb 2011 10:36pm |
Thanks Lorryman, will wait another couple of days before gnawing on my cot side and throwing teddy about a bit! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
15th Feb 2011 11:49pm |
**Update** Received the following e-mail today...
Hi Malcolm, Your mudflap extensions have been sent yesterday with parcel service. The next 50 pairs of mudflap extensions will have an upgrade. I will sent you the additional U-profile for free……………this is easy to change and you do not need to use screws any more. So everything appears rosy again and teddy can sleep safe in the knowledge he's not getting hurled about just yet!! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
17th Feb 2011 3:55pm |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
I am going to try this approach before extending the arches. The guys in Canada still haven't gotten back to me over shipping two sets of Fekete's extensions back to the UK
17th Feb 2011 4:00pm |
Entreq extension brackets for mud flaps have finally arrived! Must say at a glance they appear well engineered with all stainless fixtures and fittings!
May even spend a few hours polishing them up for extra bling factor! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
23rd Feb 2011 5:09pm |
