Home > For Sale & Wanted > [Wanted] TD5 air conditioning parts |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 |
I have most bits left over from my TD5. Everything in the photo. Including the extended nose cone which you'll need to fit the condenser.
You will need to do some wiring yourself unless your TD5 has the AC engine loom. The other thing is the compressor has the wrong connectior for one of the hoses. The connector is 180 degrees around in the connector block. The part number is correct so I don't know why that is. That meant I actually cut the hose, turned it around so one of the hoses is bodged together with rubber hose and hose clips. Other than that I believe this is everything you will need. You can weld the hose if you can weld aluminium, otherwise you way need a new hose and a correct model connector block for the compressor. If it's of any interest to you I'm open to offers. Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
18th Jun 2016 7:59am |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 |
PM sent
18th Jun 2016 8:16am |
Wish I'd asked now as I've been looking for ages if anything goes wrong I'll have 2nd dibs at the right price Ray
18th Jun 2016 11:52am |
Looking forward to having cold knees
18th Jun 2016 11:58am |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
I have the dash bottom (post 02), some hoses, grille and some other parts. If you're still looking.
23rd Jun 2016 2:37pm |
We've agreed a deal but thanks for you message…@mk1collector may still be looking?
23rd Jun 2016 5:23pm |
