Home > Puma (Tdci) > gear stick |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
8th Dec 2008 6:26pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5029 |
If your on about the gearstick vibrating and causing a noise - i get it at some some revs and apparently its the selector plate that needs replacing as its not holding tightly enough. Mike
8th Dec 2008 6:41pm |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 |
when your doing about 60 the stick is shaking side to side quite bad
8th Dec 2008 10:02pm |
Yep I got a new box but the new one does it |
8th Dec 2008 11:03pm |
I think Land rover are starting to take the p**s out of us you know
8th Dec 2008 11:06pm |
austen Member Since: 11 Mar 2008 Location: Sydney Posts: 52 |
I notice chatter in 6th at about 110kph when backing off the throttle. When re-applying power it is there again, briefly. I mentioned it to the dealer and he said it is a transfer case bearing. However the noise is there again momentarily upon starting, but only when the clutch is not depressed (the handbook says to depress the clutch when starting). This could not possibly be the transfer case as the gears would be stationery with the main gearbox in neutral. It could well be the selector plate,
Austen. |
9th Dec 2008 12:42am |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 |
I think "simonpuma90" has a valid point. I've been without my Puma 90 for 3 weeks and a day now while they (the dealer) sort out gearbox and driveline issues. Land rover have washed their hands of it saying my contract of sale is with them not LR Thanks a bunch for your help LR!!!. They're now apparently waiting for a special transmission tool from SPX.
Bosun. |
9th Dec 2008 8:12am |
Yes thats because its the selector guide - which wont have been replaced and thats what you need replaced. Mike |
10th Dec 2008 2:13pm |
