Home > For Sale & Wanted > [For Sale] Pair Wipac LED front sidelights - as new |
dunc Member Since: 31 Dec 2015 Location: surrey Posts: 132 |
Bought new from MPS Trading:
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...Sw3oBTyPQk I have now changed my plans for the front of my Defender. In original boxes with manufacture date of 27/2/16. Fitted for one week, obviously as new. Complete with new unused stainless screws should you need them Genuine Wipac, E marked. £22 including postage |
25th May 2016 9:16am |
dgravedigger Member Since: 03 May 2016 Location: Gozo Posts: 45 |
link is not opening. Make sure you have the right link or post the item number please
25th May 2016 10:48am |
Thanks dgravedigger
Ebay item # eBay Item No. 261407069987 |
25th May 2016 10:50am |
Hi Martin
If you are near your Defender it would take you 10 seconds to remove the two fixing screws and check. My Defender has a white plastic plug that the fitting connected to the light slides into. The two pieces are held together by a latch on the white plug that catches onto a lug on the black plug. If you cannot check on your vehicle perhaps MPS would confirm for you? BTW when you pull the two bits apart be sure to hang onto the cable from the wing - it has a habit of disappearing into the hole and can be tricky to find again! Hope that helps? |
25th May 2016 12:14pm |
hxk494 Member Since: 29 Apr 2013 Location: Edinburgh Posts: 237 |
Not near just now but pretty sure that's the same, remember fishing the lost plug out with bent wire before! I had a look online and suggestion is connectors [/i]may need to be reversed but that's doable.
I'll take them please, could you pm payment info, assume PayPal is OK? 1996 300Tdi Defender 110 |
25th May 2016 12:23pm |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 843 |
In case the other offers fall through, I'll have um please
If not I may order a pair anyhow, they look smart |
25th May 2016 9:12pm |
