Home > Tdi > 300tdi exhaust |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
Check out ebay .
19th May 2016 6:13pm |
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 |
We fitted our own, Bearmach from Britcar. Took a bit of fettling, did all the rubbers as well so it should be OK for a while
19th May 2016 7:45pm |
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 |
I got mine at Paddocks, fitted it myself 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
19th May 2016 8:55pm |
Cheshire Dave Member Since: 05 Jun 2014 Location: Chester Posts: 119 |
Thanks guys, but being one of those people who shouldn't be allowed to use spanners I'll have to take it somewhere, perhaps not to far away.
But where ? Dave |
20th May 2016 8:58am |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 941 |
You could buy the new exhaust pieces online and take it to your local garage. I'm sure they'd be able to do it; at a cost of course. 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold 1985 Land Rover 110 ex mod project Tithonus ~ Sold |
20th May 2016 9:59pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
Did 300tdi's have cats? I assumed not as early TD5's didn't...
20th May 2016 11:29pm |
I think so as I've seen down pipes with cats for sale, whether they were standard out the factory at some point I have no idea. 1999 Land Rover Defender 110 td5 station wagon
20th May 2016 11:52pm |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
Mine is one of the last 300tdi and is not possessed of a catalyst however do be careful with the new pattern exhausts as I have found in my ownership of the car that 2 years is a very good life expectancy with moderate use for an exhaust. It's the seams and welds that don't seem to last. I suppose it is a matter of getting what you pay for and financially it's not too painful if you are doing it yourself it's just a pain having to consider an exhaust system a biannual service item. Oh and I don't find it any better if I have bought from paddocks or eurocarparts or the first time from kwik fit they are all about as bad as each other. Rhubarb and custard let fly with their secret weapon.
21st May 2016 5:56am |
Seabreeze Member Since: 23 Mar 2016 Location: Suffolk Posts: 47 |
Hi Cheshire Dave, check out "Demand Engineering" in Ipswich: http://demandengineering.co.uk/. They make fantastic stainless steel exhausts, bespoke for all sorts of specialist vehicles, but they are Defender enthusiasts! I bought a system for my Defender 300Tdi, it's a work of art and has a lifetime warranty, they will fit them too, if you wish. You can have a standard system or any permutation of" specials", I just went for a relatively standard straight through system, mine was designed to be quiet, not noisy.
24th May 2016 11:24pm |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
I'm assuming this has now been done,....any feedback.? but regarding 110's, on mine years ago the cat downpipe was swapped for a non cat type, and the centre box swapped for a s/s straight thro' So maintanence wise I now only have to worry about the rear section. At about £20 every 2 years its no big deal, but I have smothetred both ends of the box with vaseline. and it does seem to keep rust at bay/. i k now they rust from the inside out but having a straight thro' from front to rear box should help reduce the build up of moisture.
7th Jun 2016 9:07pm |
Hi yostumpy. You clearly know ago ideal more , and have more experience, than I do with Defender exhausts! Yes my new system has been fitted, straight through with one box, I asked for it to be quiete rather than noisy. I now barely hear the exhaust note over the din of the 300 Tdi engine. I have driven only 200 miles on the new system, so I have little to report, other than the work ma ship looks very good as does the stainless steel material.
14th Jun 2016 1:18pm |
