Home > Maintenance & Modifications > MT82 Output Mod - Help |
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 |
So I've replaced the clutch and have come to fit the MT82 output mod. My original was dry as a bone and had substantial wear.
So far I've followed the WSM to the letter and have got to the part where I fit the Ashcroft aluminium housing with its double O-rings at either end. On the first attempt to fit it I tried with all the gubbins in place and with Loctite as I expected it to be a simple job and just whiz on. Only it didn't. After cleaning off the Locitite and trying to fit it a few times I figured out that If I removed the output shaft it span right on. As soon as I put the shaft in again, it feels like its cross threading. I've attached a video to demonstrate the issue. (Sorry don't know how to embed it) http://vid12.photobucket.com/albums/a223/C...o4obz0.mp4 Note there are no O-rings used for this video. However, the ally housing will screw on to the output "cup" with the 2 large O-rings in place. It just makes things stiff, so they are not to blame which was an early thought of mine. Another thing to note was that upon disassembly of the first attempt there was a thin sliver of ally where the 2 large grooves are either side of the cup. I decided to take a needle file to the leading edges to give them a chamfer, as my initial assessment was that the thread on the "cup" was acting like a tap. Click image to enlarge I'm now at a loss!?! Any help gratefully received. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
17th May 2016 5:35pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Interesting, as the housing spins on freely on its own but not with the shaft in place, and as it is such a snug on the shaft, fit do you think it points to a misalignment in the splines & shaft as that is what it strikes me as. Steve.
17th May 2016 6:09pm |
R1200GS Member Since: 12 Jul 2015 Location: Hampshire Posts: 265 |
How did you get on?
Thanks for the video too |
21st May 2016 9:19am |
All sorted now.
See here.... http://www.defender2.net/forum/topic2032-13650.html Cheers |
21st May 2016 2:56pm |
Thanks for that
Did you fit the IRB paddle clutch as well? How are you finding the two mods combined? Very interested in your thoughts as planning on doing this myself. Cheers Dave |
21st May 2016 4:22pm |
I have done both but the 110 wont be on the road for a while. Got a lot of big jobs to do.
Will defo report back when done. |
21st May 2016 4:54pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16895 |
What actually was the problem?
21st May 2016 5:36pm |
The ally housing bottomed out before tightening up on the threads. Ashcrofts sent out a new ally housing and output shaft and it went together perfectly. Hopefully it will do the trick!
21st May 2016 6:22pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3615 |
hi Cetane how has the clutch and shaft worked out? DEFENDER 90 TDCI XS,
16th Aug 2016 9:19pm |
Sorry for the delay in reply.
Not been on the forum in a while. Have been busy with other things, and only really got the 110 back on the road a couple of weeks ago. The ceramic clutch was poo. Rattled like mad due to poor build. Swapped it out for an organic jobby which seems to be ok. Not done enough miles yet to comment on the output mod. No leaks as yet though. Cheers |
2nd Dec 2016 4:11pm |
Jano300783 Member Since: 12 Aug 2017 Location: Zarzalejo Posts: 3 |
Well this week I downloaded the transfer to repair it and when you remove it you see the output shaft that comes from the gearbox. The case is that the striation is quite worn and wanted to change it, but there is no way to loosen the screw. So I am giving Sticks of blind since I do not know if it looses right or left.
Has anyone ever taken it apart? |
13th Aug 2017 12:48pm |
13th Aug 2017 12:49pm |
