Home > Spotted > What was that then?
BBSJK
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
What was that then?
Sat in a queue on the way home from work today (in the Citreon Embarassed ) and a very nice CSW went past and pulled up at the lights. It had a private plate on it so what was it a TD5 or a TDCi?
I usually tell by the simple bonnet bulge but it had its back to me. So how many seats in the back? It was dark so that was a no go Rolling Eyes .
That has brought me to a (very sad) question. How can you tell the difference between a Puma and the older Landy's?
1) Bonnet Buldge
2) Seats sidways in older one and forward facing in the puma
3) fake vents in the front (but I guess you'd have noticed the bonnet by then!)
4) Any more ?
JK No the other left . . .
Post #53038 14th Jan 2011 9:43pm
Glynparry25
Re: What was that then?
Do you mean the ones on the headlamp surrounds?...... Td5 had them too.
Bit hit or miss but the Tdi/ Td5 had a sticker/badge behind the front wheel arch stating it is Tdi/Td5 where the TDCi has nothing.
Glyn Sheep
Post #53039 14th Jan 2011 10:05pm
110SEB
By the Defender badge on the rear off side. The Puma's badge is onderlined. Others aren't i think.
By the rustiness of the rear x member!
By the four plates with two bolts in each that connect the rear x member to the body - on the Puma they're on the outside, others the inside or vida versa? Can't remember, it's Friday, i'm on my second bottle of Cotes du Rhone!
By the bulge of the vents on the dash if you can catch a glance inside.
By the number of rivets on each side - Puma 17, Td5 16. (Joking Whistle )
Post #53040 14th Jan 2011 10:07pm
Glynparry25
Changed to the inside with Td5 and same on Puma. Went from outside on the Tdi.
type the reg into the DVLA database Whistle
Glyn Sheep
Post #53041 14th Jan 2011 10:15pm
AndrewS
If moving at the time of the spot open your window and listen, if its a Puma you will hear the wining of the diff.
If stationary at lights etc, if its Puma you will hear the clutch rattling. 130's have feeling's as well you know Smile
Post #53042 14th Jan 2011 10:18pm
110SEB
Laughing Rolling Eyes
Post #53043 14th Jan 2011 10:22pm
mick
Andrew have you got anywhere with the engine tune yet .
Post #53044 14th Jan 2011 10:22pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Bow down Bow down spot on Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #53045 14th Jan 2011 10:23pm
AndrewS
No Chap
Been very busy at work so not had chance to get J-Lo back to the dealers. 130's have feeling's as well you know Smile
Post #53047 14th Jan 2011 10:30pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Glyn Sheep
No, I'm guessing fake air vents under the windscreen - the one thing I really miss! Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #53048 14th Jan 2011 10:53pm
BBSJK
I was thinking of the fake vents under the windscreen. I was expecting the miss those but I can't really sy that I do.
I guess the Puma would be the one of the AA recovery truck then?
I played 'spot the difference' when I first got the puma with my 1986 90 and found the mirrors even had the same serial number of them!
Post #53049 14th Jan 2011 11:11pm
AndrewS
They are not fake vents under the screen. I think I was told that the two embossed rectangular panels are there to retain strength in the bulk head. 130's have feeling's as well you know Smile
Post #53050 14th Jan 2011 11:20pm
shazzy90
the only way to spot the differance between all models tdi,td5 tdci is to check the tax disc if it is not a commercial,a tdci will pay £400 plus atdi and td5 will pay £220
Post #53053 14th Jan 2011 11:53pm
landy andy
If you are that close you can look through the window, and see the difference.
The difference behind Tdi to Td5 are easy from behind due to the exhaust change, and even the fog/reverse light lights are an indicator (but later Tdi's also had the round ones)
But the difference Td5 to Tdci from behind......................
No can't think of any
Andy
Post #53074 15th Jan 2011 11:17am
mse
Rectangle Red Reflectors on the rear.
Generally the people going slowly looking in pain in the TD5...TDCI happy people getting somewhere in warmth silence and comfort Embarassed Rolling with laughter Whistle Mike
Post #53083 15th Jan 2011 12:00pm
