![]() | Home > Td5 > Eberspacherfiller neck fuel take off |
chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 410 ![]() ![]() ![]() |
Has anyone installed a filler neck fuel take off for an Eberspacher?
http://www.bowerspartsonline.co.uk/brands/...pipe-20300 I would be interested to hear if it went ok |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 ![]() ![]() ![]() |
I bought one of these when I heater my heater (supplied by MV Heating). I bought a new connecting pipe as well and fitted it in that. Works well and was easier than removeing the fual tank etc. Remember to buy the extra clips to secure it.
trooper Member Since: 11 Mar 2014 Location: west sussex Posts: 102 ![]() ![]() ![]() |
In my TD5 90 I have an additional fuel tank fitted, which connects into the filler pipe. Will there be sufficient space to fit the eberspacher neck fuel take-off as well.
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 ![]() ![]() ![]() |
I have a earlier tank with a spill off pipe blanked which I used for my install.
I did consider this but the cost put me off but looks a dead simple fix. Only issue is if you want to add a wing tank then it wont quite fit apparently, which again was a consideration for me but may not be for you ![]() Self confessed mileage hunter ![]() |
