Home > In Car Electronics > Loud buzzing from front lights. |
7heaven Member Since: 03 Feb 2016 Location: Oxfordshire Posts: 122 |
There's not much in that corner other than lights, horn and BBUS (if fitted), washer bottle. Oh, and the headlight adjust motor . Check your headlight level switch on the dash is at '0' - maybe the adjust motor is running? 2020 110 D200 Base - Pangea with satin paint protection
2015 90 XS Station Wagon (sold) 2010 110 XS Station Wagon (stolen) |
9th Apr 2016 7:56am |
Ecosse1 Member Since: 28 Feb 2016 Location: UK Posts: 76 |
It's definitely the side lights buzzing without the key in the ignition, if they've been on for any length of time. No buzzing first thing in the morning. Maybe waters getting in and causing a short circuit.
10th Apr 2016 10:23am |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
Have you checked for for bee's or wasp nests?
Does the buzzing stop with all lights off? |
10th Apr 2016 10:30am |
Looking online, other vehicles have had a problem with the headlight adjustor motor so I'll investigate that further. It seems very like the clicking/buzzing noise others have described.
10th Apr 2016 1:15pm |
Adjustor motor it is. No buzzing when the light beam is set at position 2 or 3. I'll see what Landrover say tomorrow.
10th Apr 2016 6:14pm |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 |
mine does this, did you ever get to the bottom of it? My 90 Project : http://www.defender2.net/forum/topic52774.html
3rd Mar 2017 8:36pm |
Yes. It's the adjustor motor. Try each setting on the dash, you might lose the buzzing/clicking; if not you might need the actual motor replaced. Have you changed or removed the headlights at all?
4th Mar 2017 12:55pm |
Thanks. It was the motor. I took the headlight out and fiddled with the motor and it stopped buzzing.
I put the headlight back in and it's now fine. The car has been away for two days having a full closure alarm and immobiliser system fitted so I wonder if they took the headlights out. Thanks for your help My 90 Project : http://www.defender2.net/forum/topic52774.html |
4th Mar 2017 3:35pm |
Maybe worth put the truck in front of a wall or so, and see if both motors really do their job, meaning lowering and raising the lights step by step same level left and right. I had some problems with one headlight motor too, had it replaced several times, but it never worked properly. In the end it appeared that the real problem was with a cheap plastic piece to which the little motor connects, which was broken. This part is STC4029. More details in below thread.
Eric http://www.defender2.net/forum/topic42384....or+plastic You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
4th Mar 2017 3:49pm |
That's interesting, and a sensible idea, I'll do that thank you. My 90 Project : http://www.defender2.net/forum/topic52774.html
4th Mar 2017 4:42pm |
