Home > Wheels & Tyres > Where to mount a second spare wheel on a TDCi 110 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2277 |
i used the second row space. In my case all seats folded. Puma 110" SW
9th Jan 2011 1:30am |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Are you going to be installing a storage draw in the back? A tyre might fit between the back of the draw and the load guard. Russell
2011MY 110 XS USW Black |
9th Jan 2011 10:11am |
Not a help, but I was wondering few days ago if a thinner tires (like 7.50x16) would fit onto the bonnet? Would be cool to go back on this. Puma 110" SW
9th Jan 2011 10:57am |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 |
Ref second spare on the rear wheel carrier. Having looked at my own carrier (Sonic / Alisport), it would appear possible to have longer mounting bolts for the wheel, fix first in place, then mount second wheel "piggybacked" on first.
The kit certainly looks strong enough to cope with the extra weight, although maybe Sonic could clarify. Maybe want to fit reversing sensors onto finished article though!! |
9th Jan 2011 12:13pm |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
Thanks for the ideas - keep them coming
In terms of the questions raised: not sure if I will fit a storage drawer - the thought appeals but I wonder about the lack of flexibility that will bring to the back of the truck. But I will measure up to see if that space is long enough. If I do go with a storage drawer I had in mind to install a short chest in that area but I could do without. Also water/fuel would be good to go in the centre of the vehicle - suppose I could get a rack for the fuel and modify it to hold the spare......there's an idea Wheel in the second row where the folded up 60% seat would have gone sounds sensible If I were to take a spare tyre but not wheel for #6 how easy would it be for a puny office boy like me to change my own tyre in the field? If I were to mount the wheel against the utility side panel (inside) do you think the panel would eventually shake itself to bits? Feels like it would need a strengthening frame. Thanks for the posts so far |
10th Jan 2011 10:40pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16954 |
Changing a tyre in the field is not too difficult in the case of a steel rim designed for use with an inner tube (done it many times!) but is, I am reliably informed, well-nigh impossible with tubeless tyres, or wheels intended for tubeless tyres, due to the fact that the bead is a much tighter fit on the rim.
It may be that there are tools or techniques to allow it to be done; hopefully someone here will know. |
11th Jan 2011 12:35am |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Changing a tyre is very easy, just make sure you practice and if you have alloys you will probably damage them using tyre levers though it is possible to do it ( i use bits of old tractor inner tube to protect the alloy if it really has to be done). The only problem with taking just a tyre is if you damage a wheel as well as the tyre. i know this will be very unlikely with you carrying another wheel and tyre that you can use but its something to think about. If you think you need 2 spares then i would be thinking about it anyway. How about just carrying a emergency repair can of stuff (holts makes one i think) and a good compressor. One spare, a good compressor and a emergency tyre repair kit will normally get you to somewhere where you can source a new tyre/wheel. Would take up far less space and you can always get somebody else home in a emergency too with it or a trailer. Just a thought anyway, would save a little space. Pete. |
11th Jan 2011 12:43am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Its easy to change tyres if you have the kit. I have one of these it will even shift 19" MTR's of a D3 rim.
Bead Cheater 130's have feeling's as well you know |
11th Jan 2011 1:05am |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
you can also do it with a hi lift jack. you place the wheel with the tyre to come off it on the ground just under the heaviest point of the vehicle, chock opposing wheels, then you put the foot of the jack on the tyre next to the rim. jack the vehicle up and the weight of it breaks the bead. goes without saying really that you have to be careful doing this, but it does work. I've done it twice with a land cruiser with no drama.
i was at BOAB recently and they have "tyre pliers" which look like they'd work well. |
11th Jan 2011 11:47am |
rick Member Since: 07 Mar 2008 Location: Perth Posts: 133 |
Put it on your roof (using a roof tray) and secure it with a ratchet strap. The roof tray is extremely useful for other things as well. Standing on the roof, use a piece of rope to lift up/down the second tyre (if you ever need it - should be a rare event).
Cheers, Rick. 1998 RR HSE 2007 RRS TDV6 2008 Defender 110 2015 Discovery Sport |
12th Jan 2011 10:22am |
