Home > Wheels & Tyres > 15" or 16" Rims for a 110 doublecab. |
Most Defenders use 16" rims so they're more "standard".
10" wide rims you'll be looking at flotations sizes only I'd have thought? For most purposes narrower tyres will get you further. You can happily fit mud tyres to Boost alloys and save yourself a packet in buying new wheels if you're so inclined. 235/85, 255/85, 265/75 and at a push though not recommended 285/75 tyres all fit. 235s (fitted as standard) give you the best choice and pricing, 265s are the same diameter but are wider and were fitted to the NAS ones, 255s will give you the best ground clearance. I know very little about 15" tyres. As you get wider you need a bigger offset to keep the steering lock. As the tyres stick out further more mud gets splattered around, and too wide you need to fit larger wheel arches to stay legal. All things are possible, it's whether the extra effort gains you anything that's valuable to you. What are you using the Defender for? |
25th Mar 2016 2:18pm |
ploppy Member Since: 23 Mar 2016 Location: Norfolk Posts: 4 |
Ive got 4 16" Mods on 235 tyres Ive just changed my wheels,
Great tread and you can have the lot for £80 collected ! |
25th Mar 2016 2:57pm |
Matt003 Member Since: 23 Mar 2016 Location: NorthDevon Posts: 2 |
Thanks very much for taking the time to reply 'Cupboard'. The 110 gets used both on and off road but more green lanes than anything extreme! To be honest whilst I appreciate that 235s are the standard and most sensible option I'm looking for a chunkier look so possibly 285s but I don't want to make any expensive mistakes so all advice and experience welcome! Thanks again, Matt.
25th Mar 2016 3:29pm |
A decent set of all terrains will get you down the vast majority of greenlanes. There are some "extreme" lanes but they're few and far between and in general if you need anything more than an AT the lane isn't in a condition that it should be driven in.
As for looks, well that's down to you You can probably guess my preferences are narrow |
25th Mar 2016 4:28pm |
marsie Member Since: 18 Nov 2011 Location: sheffieldish Posts: 532 |
15x9 mach 5s on my double cab with 33 12.50 15 all terrains Standard height suspension
Click image to enlarge Previous to that had 16x8 with 265 75 16 maxxis mts Click image to enlarge Paul 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE* 2004 110 TD5 Double cab. *GONE* 2010 110 2.4 XS station wagon |
26th Mar 2016 6:18pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10568 |
Iv'e got 265/75/16 BFG AT's on my 110 pick up, good all rounder and as you do, i do green laning alot, never a problem 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
26th Mar 2016 11:10pm |
