Home > My Defender > 110 tdci Utility wagon build |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1617 |
Due a bit of an update here! Been getting bits and pieces done between other jobs and the stuff that pays the bills
Gearbox whipped out of the donor car. Click image to enlarge Engine on the stand to be stripped and rebuilt Click image to enlarge Thats looking like its got a bit warm Click image to enlarge Spun the conrod bearing Click image to enlarge All Stripped, good bores etc Click image to enlarge Some of the Body parts arrived genuine tdci tub and USW sides Click image to enlarge Hardtop body off Click image to enlarge Strip the body down to what i need Click image to enlarge USW Tub fitted Click image to enlarge USW Sides fitted Click image to enlarge Roof fitted Click image to enlarge Bit of the body work started, thats easier to do when its together, little damage to the rear quarter hammered and pulled out Click image to enlarge Axles and chassis stripped Click image to enlarge It's now off for paint Keswick green and white roof I've settled on. Now waiting on the galvanised chassis etc being returned. I'll check over all the mechanicals and change all the bushes, a-frame balljoint, springs, shocks etc. and the assembly is a walk in the park sure Last edited by NickMc on 24th Nov 2018 12:37am. Edited 1 time in total |
21st Mar 2016 1:33am |
Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 313 |
Great project!
Are you going to sound proof it? Sandy |
21st Mar 2016 6:51am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17305 |
I don't know what year the donor vehicle is, but seeing the photos of the bottom end reminds me that the early 2.4s had the potential problem with the piston cooling jets. I imagine that you're replaceing them anyway during the engine rebuild but it would, I suggest, certainly be worth doing.
Intersting thread, please keep the updates coming, especially the engine rebuild photos! |
21st Mar 2016 9:44am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7901 |
I'm so impressed with builds like this!
21st Mar 2016 10:35am |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1356 |
Awesome!!!
21st Mar 2016 11:50am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Now thats a hell of a rebuild! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter |
21st Mar 2016 1:06pm |
Thanks I'd love to get a bit more time spent at it.
It's a 2010, but the good engine was pinched and put into an 08 which that one has come out of,so there's a good chance the piston jets are the fault. Sound proofing, I'll apply spray on sound deadening under the panels that's over paintable and bed liner that's on the inside that's colour matched, I've done this before and it looks excellent and last well. |
27th Mar 2016 3:12pm |
Haven't got much done, but I did get the paint ordered and mixed up.
Still amazes me how different it can look in the tin and different lights. Click image to enlarge Good match Click image to enlarge Paint for the Roof and Wheels. Click image to enlarge Click image to enlarge |
30th Mar 2016 11:59pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
great thread not often we see puma rebuilds, i guess we will see more and more over next few years though!!
what sound deadening spray do you use for underneath? My 109 thread my youtube channel |
31st Mar 2016 9:46am |
Well feeling very guilty about building so many and letting my own sit there in limbo, but that’s always the way! I’ve tried to make a bit of a start onto this again.
Stripped the car down, started into body work, got a ton of shot blasting done, got my machining done for the engine, new piston rings, big end and main bearings, timing chain kit, gasket sets, piston cooling jets, oil pump, set of seat re-trims for the seats, cleaned up the wiring, removed the hideous chequer plate from the bonnet and gathered a stack of parts. Quality parts for the engine rebuild, Victor Reinz gasket and bolts, Yenmak rings, king bearings, BGA timing kit and new gears too. Another crank as ive two of these 2.4s to build Click image to enlarge Honed cylinder wall porn. Click image to enlarge Block all honed and washed for assembly Click image to enlarge Galvanised Bulkhead from Mosside Land Rover Click image to enlarge Bulkhead stripped pictures in reverse order for some reason? Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Chequer plate off bonnet, TIG up the holes. Click image to enlarge Shot blasting back for galvanising- think I’ve got everything? Click image to enlarge Click image to enlarge Chassis is mint quick wipe off the dust off it, think it was two years in service. Click image to enlarge Before strip down Click image to enlarge Click image to enlarge Happy and now it’s all in bits again, off to paint and I’ve started building up the components to put it together Click image to enlarge |
7th May 2018 12:28am |
Sorry didn’t see this comment, I use 3M products or Evercoat, expensive, but they last long term which is the aim for me. Big difference in quality between bodyshop products like anything automotive. |
7th May 2018 1:03am |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 815 |
Nice work there Nick....look forward to seen it finished
7th May 2018 7:30am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10378 |
Watching this with interest.
7th May 2018 3:36pm |
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 381 |
Nice work m8 keep it up
7th May 2018 6:48pm |
