Home > Maintenance & Modifications > 90 HT - Standard Stereo |
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1026 |
What year? Are we talking about the single cd slot one or the alpine BT one ?
7th Feb 2016 9:40am |
Ryderoo Member Since: 28 Aug 2015 Location: South Bucks Posts: 1658 |
My upgraded system comprises:
http://www.houseofurban.co.uk/store/p118/A...ITTED.html With this http://www.houseofurban.co.uk/store/p312/P...ystem.html Fitted in this http://www.houseofurban.co.uk/store/p309/D...ASCIA.html I am very pleased with this set up. It performs to my liking, quality sound. These were installed when I ordered my 90 from Urban. I believe the standard head unit can connect to the subwoofer/amp. Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
7th Feb 2016 10:23am |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
That´s a big subject that is well covered in various threads on this form. I´ll give you my personal shot on it. Hope it answers your question.
Starting from the factory fitted unit and dash speakers (single cone mid range and separate tweeters), and rear single cone speakers. The sound is shallow, with enough high frequency, some mid range, but no bass. The first step is a subwoofer mounted on the rear of the cubby. It fills out the missing base the standard 10" speakers cannot deliver, and is the biggest single improvement you can make. There are several that fit the back of the cubby so well they look like they belonged there. Easy to wire up. An independant fused + feed from the battery next door, an earth, signal off the rear speakers or a dedicated din off the head unit. Power signal feed (to switch it on only when the head unit is on) and that´s it. If that didn´t reach your expectations, or you want more functionality - look at an aftermarket head unit. Bluetooth (for phone and music, if the standard unit doesn´t have it), a little more power and better sound quality, and other features such as a more informative display, built in navigation or a rear view camera. At that point you are already likely to be looking at a double din installation. Because there are so many options with the head unit, it is worth waiting, reading up on what others have done, and analysing what your own needs are. The subwoofer is in my view the first and most effective upgrade, with minimal investment of time and money. I have run both my TD4´s with only Alpine subwoofers and single din head units (mid range Kenwoods) and am extremely pleased with the quality. I like to have a large navi screen mounted high up where I can see it and rotate to passenger or driver, or remove to programm seperately, so I haven´t yet gone to a double din, although they do offer some wonderful features. I haven´t changed the speakers yet, and from what I have heard and read, as long as one stays with the 10" cone size, it isn´t going to be the biggest of improvement. Please feel free to correct me on that. Also on the project list, I consider the next upgrade (before swapping the speakers) to be soundproofing. The flat aluminium and hard plastic surfaces just limit how much a good sound system can achieve. Just as important as the sound quality is the quality 0f temperature management that the insulation will give you. I have a marvelous Ebersbacher heater fitted, which we really enjoy, but notice how quickly the warmth dissapates out of the Defender on switching it off. On the move, the TD4´s standard heater and AC is excellent, but would both profit from better insulation. Here I´ve gotta Pete´s excellent thread... http://www.defender2.net/forum/topic43788.html Sorry for the length of the reply. Hope it of help. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
7th Feb 2016 12:17pm |
Darcy Fairfax Member Since: 06 Oct 2014 Location: London Posts: 721 |
Great set-up... Any closer pics of the dash and fascia? |
7th Feb 2016 12:28pm |
jbk Member Since: 22 Nov 2015 Location: Hertfordshire Posts: 181 |
Thanks for the suggestions folks. Let the research and shopping games begin!!
The car is a standard stereo spec, 15/16MY production 90XS. I don't actually know exactly what's in there yet (haven't picked it up yet), I see two speakers in the bottom of the dash panel top of footwell and i see two speakers in a speaker trim unit on the rear panels. Do you guys know what size and power these existing speakers will be? Would be there much value in just putting better speakers in the existing brackets, plugging a small back of cubby subwoofer in and keeping the existing head unit I wonder? Would the existing head unit cope with more demand I wonder, at what point do i need separate amp? Standard single cd loading Alpine head unit i believe, options codes and descriptions as on my car spec sheet below: [/img] Hmm, first time I've stepped onto the house of Urban website, yummy, some lovely kit in there |
7th Feb 2016 8:08pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
Headunit is fine, links well with Iphone, so will do sat nav via bluetooth etc. I'd upgrade the speakers first as the standard LR ones are pants. I have focal as many do. Its good but lacks bass due to there size and the acoustics of a tin can. Adding an active sub is good, various options but LR supplly an Alpine like this http://www.ebay.co.uk/itm/ALPINE-SWE-1200-...yu~lST0Q-. This works well for most, and amps arnt needed, but you can go OTT if you want
Click image to enlarge |
7th Feb 2016 8:32pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2496 |
If you only listen to Radio 4 like me then you'll be more than happy with the OEM Alpine. Bluetooth connection with iPhone is spot on. Don't understand all this tweeter/woofer stuff. I turn the rear speakers off so it doesn't upset the dogs. I know you audiophiles will be cringing but I'm an audiophilistine. Defender 90XS SW
7th Feb 2016 9:46pm |
You´ve spotted the four 10 cm units, and you´ll probably find two tweeters at the outer corners on top of the dash. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
7th Feb 2016 10:19pm |
A man after my own heart ! Embrace the philistine and I'm sure your dogs as mine do , love you for not blasting their eardrums! |
7th Feb 2016 11:26pm |
Spectre Member Since: 26 Jan 2016 Location: South East Posts: 228 |
Great set up. Exactly what I am going for! Please post more photos. |
8th Feb 2016 1:19am |
I am away from my 90 for a week, working away, back on Friday. I will take some piccys over the weekend. Cheers Simon
8th Feb 2016 6:04am |
SS90 Member Since: 16 Nov 2013 Location: Uk Posts: 372 |
Really depends what sound quality you're used to I suppose, but I find the factory fitted unit just fine.
8th Feb 2016 7:57pm |
Thanks for the input folks. I'll let you know what I go with and how it works out. On this subject, though a bit biased in terms of the supplier, i thought this article was interesting re. OEM electronic equipment vs aftermarket tech;
http://www.pistonheads.com/features/ph-fea...rket/33576 |
10th Feb 2016 4:21pm |
Darcy Fairfax and a Spectre, here are some more photos as you requested.
Excuse the over exposure form my IPhone, brilliant sunshine this afternoon. And yes I know, it needs a good valet. Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
11th Feb 2016 5:47pm |
