Home > Td5 > Misfire? |
Loz2286 Member Since: 31 Aug 2015 Location: High Wycombe Posts: 121 |
Not had a chance to sort it yet, long days at work this week and dark when i get home. I don't get smoke on start up, just a misfire through the rev range, coupled with the diesel leak. Parts should be here tomorrow so I'll get on Iit over the weekend. 1999 Td5 110 CSW
1961 Series 2 88 LPG |
22nd Jan 2016 9:29pm |
before you go replacing injector at £ 500 each give Hickleys a call you can refurb injectors https://www.hickleys.com/ |
22nd Jan 2016 10:47pm |
Over this weekend I've done the FPR and the injector loom. While I've not been for a long run, nipping round the block has resulted in the engine settling quickly into a nice rhythm with no apparent misfire. I'll give it a blast up some local hills later this evening.
Thanks for all the advice so far. 1999 Td5 110 CSW 1961 Series 2 88 LPG |
31st Jan 2016 6:12pm |
Yep. All sorted. Running sweet as a nut, including a 75mph blast up the A404. 1999 Td5 110 CSW
1st Feb 2016 1:49pm |
good result
1st Feb 2016 1:56pm |
