Home > Technical > Oil....what the mechanic told me |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4504 |
While getting the Defender serviced last week I mentioned to the mechanic that I was considering getting the oil changed at six monthly intervals. He dipped a finger into the oil that had just come out of my sump, rubbed the oil between his thumb and finger then wiped his finger with a cloth. The cloth took ALL of the oil off his finger. This test he said showed that the oil was still O.K. and did not warrant twice yearly changes.
He did the same test on oil that had come out of somebody else's car but the cloth could not remove the oil from his fingers which showed, he said, that it was well used and should have been changed earlier. He showed me my old filter element but apart from oil it was "clean" whereas the filter from the other car had blotches of thick oil adhering to it which again showed that my service interval was fine but the other car should have been serviced earlier. So if you want to check the condition of your oil just rub your finger on the bottom of the dipstick and wipe it off with a cloth. Not scientific I admit but it's from a mechanic of many years experience. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
23rd Jan 2016 4:30pm |
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 260 |
Or send a sample off and see if it's broken down at all
http://www.millersoils.co.uk/automotive/millercare.asp 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
23rd Jan 2016 6:53pm |
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 |
Sounds like a bit on an 'Old School' mechanic.
Meanwhile at other locations, huge investment is being made in labs where highly skilled chemical scientists are developing lubrication for specific engines, applications and lifespans. |
23rd Jan 2016 7:47pm |
It is just a simple test to show if there is any "life" left in the oil. It is not ment to take the place of indepth laboratory testing. I am also aware of the dangers of used engine oil but the amount is miniscule and would only be applied to the fingers very occasionally. 1982 88" 2.25 diesel
24th Jan 2016 12:20pm |
I'm sure it can't hurt - might give it a try next time the bonnet is up
25th Jan 2016 10:13am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
AFTER A FRESH OIL change I can always hear the engine (tappets) getting noisier after only a couple of weeks. Pov.spec,ftw. 2006, 110,TD5.
25th Jan 2016 4:40pm |
