Home > Td5 > TD5 poor fuel economy |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2876 |
Fuel leak
17th Jan 2016 7:23pm |
fuel regulator driver side back of engine
http://www.discovery2.co.uk/Fpr.html |
17th Jan 2016 7:30pm |
On the bell auto website it shows you how to check the maf with a multimeter (just to rule it out again) as four in a year could mean there's a problem somewhere else that's killing the maf? Ray
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 |
^^^^ Do you have a K&N fitted?
17th Jan 2016 8:02pm |
Jago Member Since: 15 Jan 2016 Location: Somerset Posts: 7 |
I have a piper cross filter similar to k&n. What to check on fuel regulater?
17th Jan 2016 8:29pm |
at the back engine driver side if fuel regulator is leaking smell of fuel and fuel run down over starter motor and drips off bell housing
17th Jan 2016 8:40pm |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 723 |
Hmm so I might have a similar issue. Car has dropped a couple of mpg no matter how gently I drive it - and its started leaving a drip where I park it, but is using no oil.
The problem is the undertray is preventing me from seeing where its coming from - and its not dripping to the point where I can actually sit and watch it. Its difficult to get my hand down under the regulator to see if fuel is coming out - but can you lose a significant amount of fuel out of it, or is it just likely to be a mild drip which isn't too critical in the short term? Would have liked to have limped through to warmer and drier conditions to make a more thorough assessment. |
25th Jan 2016 11:13pm |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
Not sure if the Piper cross filter uses oil like the K&N, but that oil will kill your MAF very fast Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
26th Jan 2016 5:30am |
hopeydaze Member Since: 11 May 2011 Location: Bath Posts: 30 |
Also worth checking the fuel filter on the outside of the chassis just behind the drivers door. Mine leaked pretty badly at one time
27th Jan 2016 3:06pm |
Have looked on the bell auto site and it said check maff reading on pin 2 with multimeter which I have done but have no reading but on pin 3 I get 1.4-1.5 so thinking maff might be at fault has anyone got any other ideas before I spend another £60?? Thanks
30th Jan 2016 9:02pm |
Have you checked in the red ecu plug to see if there is oil in there? Ray
30th Jan 2016 9:19pm |
Yes replaced a couple of months ago by landrover dealer
30th Jan 2016 9:47pm |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
I would disconnect the loom going to the maf and try that for a week or so and see if theres an improvement 2004 TD5 Defender 90 xs station wagon
30th Jan 2016 10:56pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
If you look at the FPR (rear right side of the block as sat in the drivers seat) then you'll see a suspicious clean/dieselly streak below it! Or if it was as bad as mine, when the engine is running you'll see the hose along the side of the block squirting diesel everywhere. |
30th Jan 2016 11:01pm |
