- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Technical > Transfer box swap... fallen at 1st hurdle - seized handbrake |
g-mack
29th Dec 2015 12:13pm |
Rickydodah
Re: Transfer box swap... fallen at 1st hurdle - seized handb | |
Mean Green wrote:I recently bought a replacement 2nd hand transfer box attached to a ZF auto box from a Rangie (although I suspect it may actually have been a Disco). It has been in storage for months (possibly years).
I want to swap the transfer box onto the LT77 on my 200tdi.
I started to split the donor 'box yesterday .... or at least I tried to split the boxes and have fallen at the first hurdle. There is absolutely no movement in the handbrake and it appears to be completely seized.
So how do I free off the drum to allow me to remove it? Is it just a case of knocking 7 bells out of it until it submits or is there anything else I can do?
Does the drum rotate at all? Have you wound the shoe adjustment off? There's normally a fair amount of adjustment which will release the shoes from the rust on the drum. I started with nothing and still have most of it left!
29th Dec 2015 12:17pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
