Home > Td5 > TD5 Breathing problems |
martindavis Member Since: 10 Nov 2015 Location: Cumbria Posts: 20 |
Hi could it be injector seals giving off diesel vapour run the engine with the rocker cover off to see if its anything you can see
21st Dec 2015 10:27pm |
tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134 |
I had thought about the injector seals but as I had replaced them about 3 years ago and18,000 miles thought they would be OK. Defiantly worth a look, could it be that simple, fingers crossed, thank you
22nd Dec 2015 8:41am |
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 260 |
What sort of mileage are you looking at on your engine? 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
22nd Dec 2015 12:04pm |
Not sure of the mileage on engine, clocks have 187000, but it has had a later 15P engine fitted, the motor is a 2000 MY, I was told the original engine had the oil pump bolt issue at around 87,000. The vehicle was owned by EDF energy, however know one had the information if a new engine was fitted or a second hand one. I've own the car nearly 5 years and the guy I bought it off had it for two years, he bought it direct from EDF, the later engine had already been installed.
22nd Dec 2015 2:14pm |
