Home > Td5 > Problems with the heating |
jesperjes Member Since: 26 Dec 2013 Location: Denmark Posts: 9 |
I'm having problems with my 2002 110 TD5. The heating inside the car has a life of it's own. Sometimes it works fine and then suddenly only cold air is coming out. The needle in temperature gauge is a little to the left of 12 o clock. If I turn on the Webasto while driving when cold air is coming out I can mostly get hot air again. When the Webasto has run for 5 min I turn if off and hot air will continue, sometimes cold air will return. It is different when the hot air stops, it can be in city traffic or on the highway.
The Webasto runs every morning and the car delightfully warm when I get in. I've noticed that there is some overpressure in the system next morning (before the Webasto) if I remove the cap from the expansion tank. I can also see traces of coolant on the expansion tank. I'm loosing about ½ litre of coolant every other week. I can't really see any leaks in the system. Any ideas of where to look? |
4th Dec 2015 2:25pm |
Over pressuring suggests head gasket Ray
4th Dec 2015 4:24pm |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2076 |
Check your water level in the Radiator header tank - we had a couple of TD5's and the water seeped away some times and the temp dropped on the heater. (on both the Defender and Disco 2 ) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
4th Dec 2015 5:21pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Check the operation of the thermostat.
Cracked heads are common too... check your oil level, see if any coolant has been making it to the sump. Have you had any excessive white exhaust (burnt coolant)? May want to have your oil tested for coolant. When you see that much coolant disappearing, you have to know it's going somewhere. It's leaking out... or leaking in. |
4th Dec 2015 5:27pm |
RILEY Member Since: 01 Feb 2013 Location: United Kingdom Posts: 35 |
sounds like pressurisation causing possible air locks hence sporadic cold heater had a rangerover do this ,turned out to be a cracked head good luck with it hope I'm wrong one life, sell it
4th Dec 2015 11:58pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
My td5 used to behave strange and do similar to yours. It was the expansion bottle cap. The relief valve was broken and vented constantly allowed the fluid to dribble out of the cap.
I had the car pressure tested and found a leak in the heater matrix but nothing else. Talking to the local indy they told me the caps sometimes fail. Mine has been fine since and covered several thousand miles 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
5th Dec 2015 2:29am |
