Home > Technical > Yet another noise |
Timo Member Since: 14 Jul 2011 Location: Peterborough Ontario Posts: 171 |
So i have a funny noise coming from what seems like the right front
Its almost like a mudflap or something hitting the wheel or propshaft. It winds up louder at about 40km/h and up It is more noticable when coasting or not accelerating. In out out of gear it makes the noise It still makes the noise when coasting at 40km/h when I turned off the engine. Out of gear. And coasted to a stop Tapping the brakes makes no difference I have checked all fluids (diffs. Swivels, gearbox, transfer box). Greased propshatfs. Checked for something rubbing I even took off the front propshaft tonight and checked for play in the transfer case output. (No play) I changed the front pinion seal in the front diff as it was leaking. Thought it might be a busted seal. But the noise is still there Any thougt or opions on things to check? I am a bit stumped Cheers Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
1st Dec 2015 4:20am |
Wheel bearing? Or stone or dirt between wheel and brake guard? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
1st Dec 2015 7:35am |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
More detail on the noise! Is it a hum drone rattle, whirring, tapping,grinding, etc etc My 109 thread
my youtube channel |
1st Dec 2015 9:51am |
Thanks for the quick replys
Both wheels have been up in the air and off. No play in the bearings when pulling on the wheel No odd noises when spinning the wheels when jacked up The noise sounds like something like a blown bearing or shaft My fist guess hearing it was the pinion seal was broken and rubbing on the diff output. But that was crossed off Both front brake pads do drag a little but can spin How freely should the wheels spin (maybe the bearing are binding a bit?) How else can I check the wheel bearing if there is no play in the wheel Thanks Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) Last edited by Timo on 1st Dec 2015 7:08pm. Edited 1 time in total |
1st Dec 2015 12:58pm |
G-mack
Sounds a bit like a what-what-what-what, or whit-whit-whit-whit, said really quickly over and over. This would increase and decrease in line with the speed regardless of engine on or off, clutch in or out, brakes on or off. I even checked to see if I had a loose mudflap. I didn't' actually check for stones in the tire, - will try that tonight along with swapping wheels around to see if the noise moves Oh - and through all of this I have now found a small hole in the frame inside the wheel well behind the brake hose fixing point Thanks Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
1st Dec 2015 2:56pm |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1285 |
+1 for a stone or other solid object stuck in the tyre based on your what what what / whit whit whit description.
Hopefully an easy fix, although if it's a great big nail or screw, best to leave it in until you can get to the tyre repair shop. Had a similar noise on my car last year and foolishly pulled out the washer headed roofing nail. Then the hissing began |
1st Dec 2015 5:59pm |
Well I went for the easy ones first
No stones in the tire or stuck in the pads Swapped tires (no change) Checked bearing - couldn't actually get the lock nut off !!! but re greased, it seemed fine from spinning Checked pads as they were dragging a bit Took it out for a spin, since I don't have my cubby box back in I can access above the transfer box. I took this video. Really seems to me to be either the transfer box, or the tranny. Much more prevalent when the power is off I took this video for sound and it is pretty clear https://www.youtube.com/watch?v=5tz_XA67Ghw Any thoughts? As much as I enjoy spending time working on my truck I much more enjoy driving it...... Thanks Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
2nd Dec 2015 3:50am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Is your handbrake drum tight? My transferbox output flange was a little loose and that made a similar noise. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
2nd Dec 2015 8:17am |
No chance to work on the truck last night.
I will check the handbrake drum and contents as my next step, then the transfer box output. I tried shifting it into 4L the night before, although I couldn't really get up much speed I think the noise went away.... One of the guys at work listened to the noise and he said the answer is quite simple. There is actually someone playing the drums in my transfer box / gear box! T Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
3rd Dec 2015 3:33pm |
ooh thats quiet bad, is your speedo cable in properly? although that sound a bit too loud for cable! My 109 thread
3rd Dec 2015 3:39pm |
did you drive it with prop off? this is my video when my td5 prop was dodgy
My 109 thread my youtube channel |
3rd Dec 2015 3:40pm |
So after driving with both the front and rear propshafts installed I isolated the noise to the tranny. My mechanic friend thinks it is the reverse idler gear. Not wanting to wade into a rebuild I was able to fine a used R380 tranny and LT230 for Can$300 which is only about 200pounds. I had to do a lot of swapping little bits here and there but it was pretty straight forward. Just time consuming with only me working on it
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
31st Mar 2016 2:47am |
The old transfer box always felt under geared. Having to rev really high in 2 to not get bogged down in 3rd
This should help Click image to enlarge Although the speedo is now reading 10km to high at only 60-70km/h The used rebuilt transfer box looks like it is in excellent conditions. I bought new output seals but the ones in it looked brand new Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
31st Mar 2016 2:49am |
Little bit of homemade tool bodgery that worked really well
Click image to enlarge This brass ring was needed on the original transfer box. The rebuilt one has a flange built into it that I think renders this piece redundant as it would not go in without binding. No leaking whatsoever Click image to enlarge Back together Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
31st Mar 2016 2:55am |
