Home > Td5 > Front door seals (lower) |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5745 |
Today I finally got around to replacing the lower door seal on the drivers and passenger doors.
On opening the door, the door now feels more springy than before, so hoping its a good seal. But.....there is still a gap which I can see daylight through (circled) Click image to enlarge Which seal am I missing to stop A) Daylight B) Draught The daylight is the corner of the door where it meets the sill/B bottom of the B pillar The seal I fitted was http://www.ebay.co.uk/itm/Land-Rover-Defen...SwrklVbvs~ (Gen LR part) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
27th Nov 2015 7:48pm |
your missing these
27th Nov 2015 8:06pm |
two per door
27th Nov 2015 9:06pm |
One each corner, B pillar and A pillar? Stuck to the door or to the body work ? 1999 Defender TD5 110
27th Nov 2015 10:28pm |
One each corner, B pillar and A pillar yes
Stuck to the door |
27th Nov 2015 10:31pm |
Excellent - cheers. 1999 Defender TD5 110
27th Nov 2015 10:37pm |
As a side note just ordered new rear door seals but have gone for the later Puma style ones as they look better than the L shaped rubber strips. I might consider doing the same to the front doors as well.
Just wondering, do the later Puma seals negate the need for the foam pads? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
30th Nov 2015 3:04pm |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 |
Simple answer yes on a Puma not sure about a TD5.
30th Nov 2015 3:22pm |
no because they have side rubber back and front but to fit them on older door isn't an easy job !
see below |
30th Nov 2015 3:23pm |
Cheers Driver 9
What makes it a difficult job to fit these seals to a Td5? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
30th Nov 2015 3:35pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
Some good info on fitting the later seals to TD5's here
http://www.defender2.net/forum/topic6370.h...door+seals For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
30th Nov 2015 5:17pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Step by step instructions
http://defender90xs.blogspot.co.uk/2014/08...seals.html |
30th Nov 2015 6:04pm |
Cheers I will have a look. 1999 Defender TD5 110
30th Nov 2015 9:33pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
Might have to get a set of those! Need to replace all the metal at the bottom of the door first though...
2nd Dec 2015 10:07pm |
